HOW TO NEEDED: Twin disc and hydraulic throw out bearing
Old Feb 21, 2010 | 08:15 AM
awd2gen's Avatar
Looking for a how to on installing a hydraulic throw out bearing? I have a Power Train Technologies Twin disc which uses a quarter master hydraulic tob. I cant really find anything on doing a twin disc specifically or the hydraulic tob...HELP
Old Feb 22, 2010 | 04:49 PM
millsyy17's Avatar
Veteran: Army
bumpp will need to know this as well!!!
Old Feb 27, 2010 | 01:57 PM
03evoslowtion's Avatar
what do u need to know? i installed my ptt twin
Old Feb 27, 2010 | 08:59 PM
awd2gen's Avatar
Biggest question I have is with the tob and doing pedal stop.
Old Feb 27, 2010 | 11:36 PM
you just bolt the throttle body to where your clutch fork is, you eliminate your clutch fork and slave cylinder. there is 4 bolts, you have to purchase the hardware because the stock ones are to small. then run the steel braided line to the existing clutch line where the slave line was. you do not need to run any of the shims. and the pedal stop you can screw where the plastic screw for the carpet is behind the clutch pedal. i made something with a welder and a bolt. to set the pedal stop you have to first have to jump the pins in the clutch switch to start the car. then adjust pedel stop with the pedal depressed the car should go into gear fine and about 1/4 to 1/2 inch off the stop you should not be able to put into gear. make sure its not to much off the stop becasue u will push the fingers into the disks. anwser your ??'s
Old Feb 27, 2010 | 11:37 PM
throw out bearing not throttle body LOL
Old Feb 28, 2010 | 12:26 AM
after the clutch starts to break in you maybe have to mess with the pedal stop if it starts to lock you outta gear. and another thing your going to have to vacuum bleed the system to get pedal pressure or your going to be there for years!
Old Feb 28, 2010 | 10:21 AM
awd2gen's Avatar
Ha gotcha. If you could pm me a pic of the pedal stop that would be awesome. Thanks for the info.
Old Feb 28, 2010 | 10:47 AM
millsyy17's Avatar
Veteran: Army
ive been reading the pedal stop is not necessary??
Old Feb 28, 2010 | 10:50 AM
awd2gen's Avatar
I wouldn't believe that. Ptt specifically states to have one in instructions and several people point out not to forgot a pedal stop
Old Feb 28, 2010 | 11:57 AM
the pedal stop is def. necessary. unless you want to do it all over again becasue u warped the disks.
Old Feb 28, 2010 | 11:59 AM
ive witnessed it single hand. when i get my car back i can send you a pic of what it looks like. you should be fine with a bolt tho. PM will be sent by end of week.
Old Feb 28, 2010 | 12:06 PM
the cool thing is when u install this twin disk, you dont have to worry about tahat pita stock throw out bearing setup and releasing it from the trans the twin disk one jus falls right out so easy.
Old Feb 28, 2010 | 12:14 PM
TurboTim06's Avatar
i need to do a twin disk setup then cuz i HATE that stock TOB haha
Old Feb 28, 2010 | 12:33 PM
its absolutely the worst design.
