HVAC Repair - MEGA Guide
Old Mar 20, 2015 | 04:27 PM
  #136
SilverShadow03's Avatar
Originally Posted by Bushka
Yeah I saw that, too. But, I wanted to be sure there was a way to replace it before buying one. Can I just pull out the old one and shove the new one in?
Dan
Yes, you can replace it. I did on my 03 Evo 8 along with the knob...and revised cables and gears.
Just take your time and read up on it before tearing it apart.
GL!
Old Mar 21, 2015 | 08:04 AM
  #137
Bushka's Avatar
GL!
Thanks! Not to appear dense, but by "reading up" are you referring to a repair manual, or just finding other posts from people who have done the same?
Old Mar 21, 2015 | 09:52 AM
  #138
Bushka's Avatar
I guess I'm answering my own question, but it appears someone had luck in removing the control unit and popping the stem out from underneath somehow.
Old Mar 22, 2015 | 06:21 PM
  #139
Yes, it pops out.
There is a YouTube video as well...IIRC.
Old May 15, 2015 | 12:57 PM
  #140
aggieEVO's Avatar
Hey HVAC geniuses. I have a question.
My AC blows ICE COLD... as long as I'm moving.
You're all going to say - it's the compressor fan. And normally I would think you are right, because I don't have one, but that's a recent development. I had the same issue with the AC last summer when my fan was functioning properly. The motor went out about 2 months ago and was squealing like a pig, so I removed it.
While I definitely plan on replacing the fan soon, I don't think that's 100% my problem.
If I rev the car to about 1500, AC blows ice cold, low side pressures get in-check, and the pipe gets ice cold. When I let it idle (around 900) the hose is warm and my pressures are all nutty.
Clutch is engaged and not slipping, btw.
Any tips would be great.
Thanks,
Brady
Old May 18, 2015 | 02:45 PM
  #141
aggieEVO's Avatar
Nobody? I'm currently looking for a condenser fan. Any other tips?
Old May 30, 2015 | 06:29 PM
  #142
sourcelx's Avatar
Maybe its in your compressor then. Or poor wiring/operation of your fan. Those could both be related to the motor rpm's.
Old May 30, 2015 | 06:31 PM
  #143
sourcelx's Avatar
Back on subject, I realize myself and others still have this problem. I will be pulling my dash out soon for the repair and will be including lots of pic to help anyone who may be looking.
-Edwin
Old Jun 5, 2015 | 06:06 AM
  #144
SolVII's Avatar
Do a lot of the early 2000 Evo's have problematic HVAC's? Or is it just bad luck?
Old Jun 6, 2015 | 06:48 AM
  #145
aggieEVO's Avatar
Thanks. I have a second compressor. I may rent a vacuum and swap it.
Old Jun 12, 2015 | 02:00 AM
  #146
Edan toorgeman's Avatar
Hello ravman0690, thanks for this great post. It contains useful content.
But i have a quick question regarding AC Repair... I turn my Air Conditioner on and air blows but not cool. Condenser fan isn't running but I can hear the condenser turning on and off. unit is a Bryant Legacy Heat Pump. Any recommendations?
Old Aug 12, 2015 | 10:55 PM
  #147
Jeff Elinger's Avatar
Removing the HVAC control unit is a task that needs to be accomplished with great care. Only a ac system repair professional can easily handle such a task of replacing an ac system.
Old Aug 19, 2015 | 11:54 AM
  #148
Evonv91's Avatar
Huge help
Old Aug 19, 2015 | 06:24 PM
  #149
Kevin.'s Avatar
I installed the revised gears and lubed all moving parts a few years ago and now my cable is acting up again. I think it's the cable that's the problem, with that kink in it.
Old Sep 7, 2015 | 07:51 PM
  #150
Treyplay's Avatar
Thanks!
