How to: 8 vs 9 turbo
Old Nov 9, 2010 | 04:43 AM
  #46
TURBevO8's Avatar
Going to be swapping my VIII cold side to a IX cold side mated to my ported 10.5 here very soon. Hope it is worth it. Plan to add a larger fmic than my BR Deluxe, MAP intake mani, MilSpec TB, head studs, new head gasket, Perrin intake tube, maybe a EBCS, and some other little tid bits. Hopefully the area under the curve is vastly improved if the peak numbers arent much better than now. Looks pretty straight forward. Looking forward to getting started here in about 2 weeks. Thanks for the write up.
Old Nov 9, 2010 | 07:54 AM
  #47
CristianRO's Avatar
^^^ please update us with results .. Thanks.
Old Nov 9, 2010 | 10:22 AM
  #48
TURBevO8's Avatar
I am going to install all of this stuff over the winter and get a CBRD tune in late March/early April so may be a while till results come in. Plan to do the turbo and fmic here in November but probably wont get the car totally done till after tax return.
Old Nov 9, 2010 | 10:39 AM
  #49
zac5's Avatar
good info! thanks for posting it up.
Old Nov 15, 2010 | 12:30 AM
  #50
SnowtaEvo's Avatar
great thred very intresting
Old Nov 26, 2010 | 09:17 PM
  #51
Thoe99's Avatar
Originally Posted by DontStopMe
...The only line that is the same between the two turbos is this coolant line.
I just did this Evo9 turbo swap today on my Evo8. I reused this line off my old turbo but it did not fit. I had to bend the line and one of the bolts still doesn't bolt up. It's not important, but I can't see how the 2 turbos share this line.
Old Nov 26, 2010 | 09:53 PM
  #52
e4on2e5's Avatar
i've asked this question before and after 800+ views no one replied... I have a 03 with the 9.8, i just recently bought a 8.5 turbo for 150 (with everything needed to install)... My question was... What is the most i can get out of this 10.5 as oppose to a 9's 10.5... i know the housing sizes are different but i would like to know how much more i can get out of this over my 9.8... can the 8.5 support over 400whp like the 9 can?
Old Dec 5, 2010 | 07:38 PM
  #53
e4on2e5's Avatar
Bump!!!...
Old Dec 7, 2010 | 02:28 PM
  #54
45kevo's Avatar
good info waiting to do my evo turbo upgrade
Old Dec 9, 2010 | 11:57 AM
  #55
crxsti's Avatar
Old Dec 22, 2010 | 04:10 AM
  #56
evo8john's Avatar
Well you can finally have an answer sir... I am running the 10.5 hotside 8 turbo with basic boltons, stock 02 housing, no porting or anything, HKS 272s, and e85. I run about 31.5 psi and am making right around 400 whp. Another local guy here is running Kelford 272s, 31 psi, and a ported 9 turbo with 02 housing and he made 402/410 according to VD. Hope that helps
Old Dec 26, 2010 | 06:47 PM
  #57
drewbird91's Avatar
Here are some numbers from a member:
https://www.evolutionm.net/forums/ev...vo9-turbo.html
Old Apr 23, 2011 | 12:11 AM
  #58
donkey26's Avatar
this could be title, "turbos for dummies".. lol... good write up.. installing a evo 9 turbo into my 8...
Old Apr 28, 2011 | 06:24 AM
  #59
kylemcritchie's Avatar
very good info thanks
Old Apr 30, 2011 | 09:53 PM
  #60
stevenkha's Avatar
I definitely want the Evo 9 turbo! It looks like a beast
