seibon cf trunk install
I took off my tension bars in the trunk when I did mine then the install went easy.
I took off the bar to prevent my trunk from warping from the pressure the bars put on the trunk.
Easier to install the trunk with another person or two so they can hold the trunk while you line up the screw holes.
just finished installing it sits a bit high towards the end but seems to be held in tight !
i know its not going to align directly as OEM but seems pretty good to me
May also need to reverse the latch. It will help pull the rear down a little more.
Ive got a VIS and it fits about a 9.5/10 with the reversed latch, no torsion bars, and adjusted bump stops.
And to make it fit well, take down your rear seat ( back portion ) and allow someone to crawl into the trunk area, and align it from the outside with the bolts loose. Once you have her where you want to, have the guy in the trunk tighten down the bolts.
Chino051
Jan 15, 2016 09:07 PM
WTB[Northeast]: Cf doors , cf trunk
95lsvtec
Oct 12, 2015 08:47 PM
wewtRallywewt
11
Aug 20, 2012 11:52 AM
