How to Install Rear Wiper Plug
Old Sep 30, 2012 | 05:06 PM
  #46
10isace's Avatar
evodan2004's Post exact weights shows 3 lbs also.
Now if I can find 300 things I can remove that are 3 pounds or more for my DD.
Old Oct 1, 2012 | 05:02 PM
  #47
EVOVIIImadrid's Avatar
People really need instructions on how to do this?
Old Dec 18, 2012 | 08:13 AM
  #48
EVO'D8's Avatar
Curiousity but do you guys have the washer for the plug? If so, did you install the washer inside the car as like taking out the OEM washer?
Old Dec 31, 2012 | 07:05 AM
  #49
anthonyrb98's Avatar
if interested pm me, i have some plugs with washer available
Old Mar 31, 2013 | 05:55 PM
  #50
mjev8's Avatar
Originally Posted by C3L1CA
How to install rear wiper plug purchased from n1nj4 m0d3:
Time needed: 10-30 minutes depending on working speed
Tools needed:
Ratchet
10 mm socket or wrench
22 mm socket or wrench
Needle Nose Pliers (optional)
What you'll have left after the install:
Total weight savings: 1.6lbs
Installation Steps:
1. Remove rear wiper
2. Pull up wiper cover to expose 10 mm nut that holds on the wiper arm.
3. Remove 10mm nut holding on rear wiper and remove rear wiper
4. Remove 22mm nut holding holding the wiper motor assembly to the nozzle and washer assembly.
5. Open trunk and unplug the rear wiper motor. Then remove the 3 10mm bolts holding on the motor assembly.
6. Remove wiper motor. To do so you have to slightly close the trunk and pry on the trunk torsion bar. Also to remove the wiper motor you have to disconnect the wiring from the mounting assembly. To remove the wiring I used a needle nose pliers and pushed on the two ends to pop it off.
7. Next remove the "nozzle and collar assembly." You will have to remove the washer line from the assembly.
8. Remove the rubber "packing and washer assembly." To do this go inside the car and pull up on the rubber assembly and it will slide out.
9. Insert wiper plug.
You could be done now but I did 2 extra steps to make a little bit "cleaner" install and make it easy to install the rear wiper in the future if I wanted to. I installed a rubber vacuum cap over the end of the washer fluid line. This way just in case I accidentally hit the rear wiper button it didn't spray fluid all over my trunk . I also zip tied the rear wiper wiring up to the trunk light wiring so it doesn't hang down.
Step back and enjoy!
Great plug and would recommend it to anybody looking to clean up the rear end of their evo!
Old Mar 31, 2013 | 06:35 PM
  #51
ILuvJDM's Avatar
solid bump.
Old Apr 5, 2013 | 11:03 AM
  #52
steven0720's Avatar
Great write up, thanks
Old Apr 18, 2013 | 06:37 AM
  #53
skeeta's Avatar
Im definetly doing this. Looks a lot better IMO.
Old Mar 9, 2015 | 11:09 PM
  #54
Name User's Avatar
Just want to add something: You see that "packing and washer" assembly? It's the rubber thing that covers the area from the interior point of view, making it look stock.
Well, what you can do is remove the metal piece that's inside it, you can just slip it out from the rubber. Then, cut a circle hole so that it fits your new plug. Now it will look good from both the inside and the outside.
KevinD
126
May 3, 2018 05:57 AM
concept11253
May 11, 2017 11:00 PM
brett@evogb
Apr 20, 2017 10:02 AM
EvoPooPoo
47
Aug 11, 2008 08:31 AM
pnoiboy626
Jan 30, 2006 03:50 PM
