Power steering hose how to
Old Feb 21, 2012 | 07:05 AM
bubba17's Avatar
looking for a tutorial on the high pressure hose that runs from the pump, beside the cam gears, under the tcase, into the gear box. im hearing 5 million diffrent ways to do this and was curious if there was a how to or if anyone had first hand with this experiance
Old Feb 21, 2012 | 07:36 AM
AngryEvo8's Avatar
Pm bj@toxicfab I know he was talking about it.
Old Feb 21, 2012 | 12:47 PM
bubba17's Avatar
he said hes not possitive how it comes out
Old Mar 21, 2012 | 04:06 AM
Joshm3357's Avatar
Did you ever get an answer on this?? It looks like I am going to have to do this. From what I can tell it looks like the metal part of the line has a puncture where it goes above the subframe?? Not sure how it happened but from what I have found its a pain in the *** to replace the line...
Old Mar 26, 2012 | 11:05 PM
Sylhety's Avatar
Cool!
Old May 18, 2012 | 09:20 AM
greatgonzer's Avatar
I am also looking for this information. Did anyone here ever replace thiers and if so, spread the love and tell us about your experience...THanks!
Old Jun 10, 2012 | 07:34 PM
Rondata.'s Avatar
Any info on this?
Old Jun 11, 2012 | 03:56 AM
Joshm3357's Avatar
I had someone else do it
Old Jun 13, 2012 | 07:21 AM
bubba17's Avatar
it took me probably 3 hours to go by myself i just cut the out line out. the easiest way was drop the rear transmission mount, front the front transmission mount and jack the trans up it will tilt the motor enough forward. run the hose through the passenger side first and work your way around the the driver side. it may take you a min but just wiggle and move the hose side to side up and down until it frees itsself between the t case and subframe. once i got the line to the sub frame i crawled underneith and feeded it through the bottom. if you have a lonnnnng extension you can tighten/loosin the bolt by going through the rim with it on the car, under the frame to the bolt if you dont want to be bent over the engine bay. make sure you have both copper washers on the banjo bolt or it will leak and you will be pissed. make sure to put some blue loctite or thread sealant on the banjo bolt. good luck
jracer
Nov 24, 2015 06:24 PM
fr34k
Jun 12, 2012 01:01 PM
simons
20
Jun 19, 2011 06:58 AM
Gooseman396
Sep 22, 2010 09:23 AM
2StepsAhead
11
May 9, 2010 08:37 AM
