I need help on my coilover!
Old Mar 19, 2012 | 03:09 AM
mistergomez316's Avatar
I have WORKS/Ohlins Stage IV Coilover Suspension. I would like to adjust the height myself but I need a little help! Yes, I'm a noob and it already came with the Evo I bought couple months ago. I have no idea where to start. I've had Function and Form coilover for my EG9 and yes I did work on it with a help of a friend. I just wanna know the step by step since Ohlins Stage IV Coilover Suspension looks a bit different.
Here's how it looks like!
http://store.worksmotorsports.com/WO..._p/225.805.htm
Old Mar 20, 2012 | 10:45 PM
sujinX's Avatar
pics dont work
on my ohlins, the fronts on the bottom mount there is an allen bolt. loosen that bolt and remove. take the wrench and put it on the lower collar and spin it so that the WHOLE threaded section moves. then when u get it to the right height, insert allen screw and tighten.
for the rears, just break loose the lower collar below the spring and spin the top collar (below the spring) to adjust the rear height.
in the ohlins manual there is MARKINGS for the limit of the height. dont go HIGHER than the marking line on the threaded sleeve. that means there is 4-5 threads left holding it and its not safe to go further.
just found the pic. wow you bought the double adjustable one. baller.
Old Mar 21, 2012 | 05:44 AM
Originally Posted by sujinX
pics dont work
Thanks for your help! I'll check it out. And nuh, I didn't buy it. It came with it when I bought it from the dealer. I saw the receipt from WORKS Motorsports though. The previous owner spent at least 6k on my Evo. Luckily other than that everything's pretty much stock. Once again, thanks!
Old Apr 18, 2012 | 11:41 AM
*bump
EVL4B11MR
Jul 22, 2016 09:17 AM
maperformance
EvoX 'For Sale' Suspension / Brakes / Handling
118
Jul 14, 2016 12:33 PM
maperformance
14
Jul 3, 2015 01:24 PM
RallySport Direct
Evo X How Tos / Installations
21
Jul 16, 2014 07:07 PM
TommiM
10
May 13, 2014 12:09 PM
