How to install acd pump
Old Jun 29, 2012 | 02:57 AM
Quicks916's Avatar
I can't seem to find a "How to install Acd pump" thread on here. A lot if related subjects, but no real step by step instruction. Bought my evo 9 with out an Acd pump and now that I finally bought an Acd pump need info on install or a link to proper thread. Thanks in advance
Old Jun 29, 2012 | 07:34 PM
damie45's Avatar
I was looking for a how-to also. I guess I'll figure it out tomorrow cause I'm going to do mines tomorrow. It seems like the most important thing is to have 2 people to bleed the pump. One to push the gas pedal on 1 to open the bleeder valve. I did this part and it wasn't hard.
I still don't understand: with all the pumps that r failing, mitsu still haven't taken responsibility for the faulty design. We need a class action lawsuit.
Old Jun 29, 2012 | 08:03 PM
impact blue's Avatar
A lawsuit is not needed itll be just like throwing ice-cubes at the devil. If youd like I can help. What you have to do is disconnect the negative side off the battery. Then proceed with taking the front bumper off along with the dust cover and shield. I had the under splash shield removed so thats one less step I have to do.
Now I believe are two big bolds that go onto the chasis of the car where the bracket holds on to it. Before you start to disconnecting wires you want to hold a little catch bowl to catch the oil that is going to leak from out of the system. It looks kind of like a fluid brake like that attaches to it then you unplug it from the harness of the car it should take you no more than like 15 to 20 minutes if your taking your time. Hit me up on here if you need help. I should do the diy myself if you need pics. So you need a diy on the assembly itself or just the pump?
Old Jun 29, 2012 | 08:50 PM
damie45's Avatar
thx impact blue. I already took my front bumper and undercar off in preparation for tomorrow. do I just install the new pump fill the reservoir and bleed it while its on the car and keep on refilling the reservoir as needed?
Old Jun 30, 2012 | 02:56 AM
Quicks916's Avatar
^^^^ what he said. Can you be more specific were the bleeder release valve is? Please let me know if u incounter any problems with install / how to avoid these problems. How long to bleed also? Just like brakes? Until continues flow of liquid? Or is their a nother way? Thank you in advance.
Old Jun 30, 2012 | 03:01 AM
Quicks916's Avatar
Need DIY on the install process of Acd pump mainly needed.
Old Jun 30, 2012 | 03:03 AM
Quicks916's Avatar
Forgot to ask also when bleeding Acd pump, what position should key be in? Sorry if questions sound dumb.
Old Jun 30, 2012 | 11:42 AM
damie45's Avatar
I just finished mines. It took a little longer the because the pump I got was from a wreck evo with front end damage right by the pump. all the connections was damage including the harness. Taking the old pump off is pretty str8 fwd.
To bleed the system turn the key to on w/ out starting the car and have someone step on the gas while you open the bleeder valve.
There are several threads on here that explain this. Good luck.
No more 3 lights displaying. Haha! I can't believe how much corrosion was on my pump compare to the other, just by looking on the brackets u can see the difference and my car only has 33k and seen only one winter. I'll c how long this one will last, it was free so it doesnt matter.
Old Jul 1, 2012 | 02:22 AM
Quicks916's Avatar
Thats good news that you were able to get it done and that the three red lights didn't come on. The more that you guys right on here the more knowledge n confidence that I build up to do this. So I appreciate that.
Questions. Did u use a machine to bleed Acd pump or u open n close the bleeder valve by hand? Also did u bleed bother the Acd pump and transfer case. Just really confused cus theirs a bleeder valve on both and I don't understand if u have to bleed both of them. Also when bleeding, gas pedal all the way down the entire time or did u pump the gas pedal?? Thanks again guys.
Old Jul 1, 2012 | 07:20 PM
damie45's Avatar
I used the gas pedal method. I was having difficulty bleeding the system because the pump would run for a second or 2 then turn off, so it wasn't running long enough for me to bleed it, which is a good sign that the pump is working great. So after some SEARCHING I came across a UK forum which one guy say to just unplug the pressure sensor harness and plug it to the old pressure sensor that's not on the car. The pump run longer and I was able to bleed it and when I was finished I just the harness back to the pump.
tlcoll1
Feb 24, 2018 10:06 AM
silentsniper605
15
Oct 14, 2015 05:33 AM
Evolution Z
Jan 19, 2015 07:48 AM
ahr4156
24
Jun 28, 2012 09:45 AM
Evilution23
Sep 14, 2010 02:47 PM
