HOW TO: install full Auto A/C climate control
You mostly pay double for everything because of shipping.
i know i want it so bad lol. I was thinking of coming up with an alternative to this a while ago just never got around to it.
Dont get me wrong the prices where the first ones i came across and i where all in new or outstanding condition. i cant read any other language so it would be hard for some one like me to go onto other forums unless i translated to pick up the parts used. But still shipping is what gets you. The hvac controls cost around 60 dollars but then another 70 to ship?? damn!
but lexcite says he can get all the parts for 500 that's really good. lol
Maybe i could send him a pm and we could work something out
[QUOTE=LeXcite;10256680]
Needed parts.
1.1 86322C MOTOR,HEATER CONTROL (MODE) - MR568606
1.2 86322B MOTOR,HEATER CONTROL (AIR MIX) - MR568607
1.3 83928 HARNESS,HEATER - MR568601
1.4 86354 SENSOR,HEATER WATER TEMPERATURE - MR568828
1.5 87127B THERMISTOR,A/C - MR 568831
1.6 86119 LINK,HEATER AIR CONTROL DAMPER - 7801A111
2. 86206A BLOWER ASSY,HEATER - 7802A024
[4. Double din panel - 73165 PANEL,INSTRUMENT,CTR - 8002A353HA
, or just panel with two 1 din holes. One I used for audio, lower one for empty box - 73165A PANEL ASSY,INSTRUMENT,CTR. - 8002A272HA
5. Lower panel for A/C ecu - 73108 PANEL,INSTRUMENT,LWR CTR - MR 626799
6. A/C Ecu - 87022A CONTROLLER ASSY,AUTO A/C - 7820A103
7. Sensor of the outside temp. - 87406 SENSOR,A/C CONDENSER TEMPERATURE - MR 283903
8. Sensor for the Inside temp - 86353 SENSOR,HEATER AIR INTAKE DUCT - MN 134419
It come with hose, connected to heater box - 86306 HOSE,AUTO HEATER CONTROL VACUUM - 7823A003, and have temp sensor other side, and this air divider on another side - 86318 ASPIRATOR,HEATER CONTROL VACUUM - MR 568605.
9. Harness from the A/C ECU to the heater assy.
LeXcite! This is an absolutely awesome achievment that you did here, I have been trying to figure out how to do this auto heater/AC control setup. I see you posted here part numbers for all the parts needed. Can you specifically post a source of every part number that you used? Website or a Certain Website with classifieds whether it is in Russia, Kazahstan or Japan I dont care I am trying to figure out sourcing of these parts and I know if I can order stuff from Hong Kong every day on Ebay I can order from Kazahstan. Are you willing to help out shipping these parts to USA? of course for a fee to make it worth for you. Can you setup a kit. and just send it to US? oh and Can you get me access to the russian website? Spasiba.
DIY “HOW TO: install full Auto A/C climate control”.
Needed parts.
The login ins't working for me. Did anything change? And this is for http://www.japancats.ru/mitsubishi/ right?
-Acree
-Acree
I don't care so much for the Auto climate control, I'd just rather have electronically controlled HVAC. I'm tired of cables sticking etc and it'd be easier to have something like a servo motor that turns the blowers and not be cable-driven
good luck either way LeXcite and Acree!
I would not do this if the system is anything like the auto climate control in the evo x. Going from an IX to an X, The climate control is one of the worst features on the new car. It never blows the right temperature or volume of air, often opting to blow an arctic blast when the car is already chilly inside.
I just want the electronic-controlled temperature adjust and such, i don't care about "auto climate control", just don't want the crappy cable system.
basically, replace the manual cable system with electronic servo's and i'll be happy. i'd never set it to auto anyways
There isn't a truly manual mode, more of a semi-auto, since the temperature dial is still a thermostat and not a fixed mixture of hot and cold. It's a crappy system, even in "manual" mode.
After looking around, I have to ask if these components are interchangeable with mopar parts? MN124235 for example comes up as a dodge part when I search it. Same numbers, will it work?
Last edited by osetsky; Nov 13, 2012 at 11:13 AM. Reason: No item photos on vendor sites.
