HOW TO: install full Auto A/C climate control
Old Oct 26, 2015 | 07:38 PM
  #46
unihappytime's Avatar
Originally Posted by llDemonll
How did you guys wire the blower motor? The standard US motor (manual AC controls) has a two-pin plug and the controls regulate how fast the blower is spinning
The Auto Climate Controls have a 6-pin plug and I'm stuck on figuring out what wires go to this plug
Help appreciated!
Check out the pic, it's from a JDM blower the loose pin is the ground and it from the left or right corner (depends how u look at it)
The blue wire is power from the JB and the red white wire in the middle is from the AC control ECU, I guess it sends different voltages down this wire to determine the speed.
Old Oct 27, 2015 | 02:57 PM
  #47
Biggiesacks's Avatar
I think these are your three wires:
Old Oct 27, 2015 | 03:00 PM
  #48
llDemonll's Avatar
C-17 (3) is to a constant +12v
C-18 (28) is a switched +12v
Old Oct 27, 2015 | 03:06 PM
  #49
without a JDM blower you might have to come up with your own pulse controller solution.
Old Oct 27, 2015 | 03:09 PM
  #50
llDemonll's Avatar
Oh, I do have a JDM one. I have the US one back in the car because I needed something to move air to defrost my windows lol
Old Oct 27, 2015 | 03:10 PM
  #51
NVM Then lol
Old Oct 27, 2015 | 03:11 PM
  #52
wheatbix's Avatar
I always wanted to do this since moving to the US and realizing that they like to take out standard options on the Japanese models because they don't think people in the US would pay for them. Kinda annoying, even my '99 VI GSR had auto climate control and outside temperature!
The price on all those parts new seems excessive though, are there any places in the US that bring in half cuts (mostly for the engines) that you could get all of this out of cheap?
Old Oct 27, 2015 | 03:13 PM
  #53
The 6 wires could be the ones surround the "J/B" in the picture i posted then.
NVM ^^^ doesnt make much sense. Its kinda hard to figure out whats what from the diagram without having the physical stuff too.
Old Oct 27, 2015 | 06:36 PM
  #54
The 6 pin plug refers to C-28, only 3 pins used, pin 6, is the blue wire going to the JB for power, pin 3 is the black wire going to a ground, finally Pin 5 is the red white wire coming from the A/C ECU C-17 pin 2.
I guess this wire sends a different voltage to speed up and slow down the blower, bit like resister but with more speed options.
Old Oct 27, 2015 | 09:36 PM
  #55
llDemonll's Avatar
I'll have to look at it again with the blower out of the car. I also don't have plug C-28 so I've ghetto-rigged it with female spade terminals. Problem I was having is the fuse was blowing. Maybe it was the plugs somehow shorting from touching? But they're all heat-shinked and shouldn't be doing that.
Anyways for now I've re-wired the USDM blower motor back in with just the fan speed control so that I have defrost and heat
Old Oct 28, 2015 | 09:19 AM
  #56
so if the blower housing takes 3 wires then it would have to be +12v, ground, and PWM signal from the AC ECU. Which would mean the controller is built in. Using that picture unihappytime posted you should be able to figure out which pin is the pwm
Old Oct 28, 2015 | 09:34 AM
  #57
llDemonll's Avatar
correct; i basically wanted to confirm what i was thinking
My biggest confusion is that I didn't know the blower relay was "always hot" essentially so I was having troubles figuring out what wire was signaling that relay to activate
So correct, C-28 (3) on the blower is ground, C-28 (6) is power from the relay, C-28 (5) is the signal from the A/C ECU C-17(2)
Old Oct 28, 2015 | 10:03 AM
  #58
for my arduino approach im going to basically wire up a speed controller from amazon or something and use that to control the factory 2 wire from one of the arduino pwm outputs. I was tossing the idea of actually using a boost converter to pump some extra voltage into the fan for higher speed, but i gotta finish the code for these actuators before adding more stuff to the dev list.
Old Oct 28, 2015 | 10:20 AM
  #59
llDemonll's Avatar
From all the work I've done, your approach may be FAR easier for future swaps. Swapping the Air Mix and Mode motors can all be done, with some contortionist difficulty, with the entire dash in place pretty easily
Old Oct 28, 2015 | 08:14 PM
  #60
I think the blower relay is only activated when the keys are turned to 2 so it means the blower will only have power when the key are turned to ACC position?
After that the van speed is controlled by the ECU with the signal wire as opposed to the resister on our manual versions?
PS I have a JDM RS 7 so it came with state of the art manual AC
