HOW TO: install full Auto A/C climate control
Old Oct 28, 2015 | 09:12 PM
  #61
llDemonll's Avatar
Originally Posted by unihappytime
I think the blower relay is only activated when the keys are turned to 2 so it means the blower will only have power when the key are turned to ACC position?
After that the van speed is controlled by the ECU with the signal wire as opposed to the resister on our manual versions?
PS I have a JDM RS 7 so it came with state of the art manual AC
correct. blower relay is only active when ignition is in the "on" position
fan speed is controlled by the AC ecu on jdm blower
Old Dec 1, 2015 | 09:49 AM
  #62
s4m's Avatar
s4m
Thank you for this, can't wait to do mine
Old Dec 1, 2015 | 11:18 AM
  #63
llDemonll's Avatar
Good luck
I'll have a full detailed write-up once I finish sourcing all the remaining parts I need
Old Oct 19, 2016 | 07:24 AM
  #64
llDemonll's Avatar
If anyone was ever looking for this I posted it a while back after I completed my swap:
https://www.evolutionm.net/forums/ev...hvac-swap.html
Old Jan 16, 2022 | 08:13 PM
  #65
sotxEvo's Avatar
HVAC part numbers
Originally Posted by Ramen_Noodle
I couldn't find all of these parts on Mitsubishiparts.net but here is what I could find and price as NEW:
MN124235
MR626799
MR283903
MN134419
These 4 part numbers come to a total of $1,411.65 without S&H ($204.69 for USA Ground).
I could not find the following items:
2. 86206A BLOWER ASSY,HEATER - 7802A024
4. Double din panel - 73165 PANEL,INSTRUMENT,CTR - 8002A353HA (Can be purchased elsewhere)
6. A/C Ecu - 87022A CONTROLLER ASSY,AUTO A/C - 7820A103
I could be missing some items from the list, but that's just what I've discovered so far using a known (and trusted) resource for parts here in the US. I suppose the rest may need to be sourced outside of the US or you may just need to find the right part number and then locate the part(s) on MP.net.
Of these numbers is there a part number for the part that has a clip that holds the cable in place?
Old Jan 16, 2022 | 08:59 PM
  #66
llDemonll's Avatar
Not sure what cable you're referencing?
Old Jan 17, 2022 | 10:05 AM
  #67
sotxEvo's Avatar
Hvac
The cable that is connected to the temperature knob. The knob on the left side. The knob operates the cable which turns the little "gears"
Old Jan 17, 2022 | 08:05 PM
  #68
llDemonll's Avatar
You're asking about a part that's on the manual HVAC controls, correct? I don't think there's an actual part number for that clip, best bet is to look for Lancers or Outlanders in junk yards and source from there.
rayman0690
Jan 4, 2026 07:20 PM
llDemonll
Sep 22, 2021 05:43 PM
GetFoxed
Jun 12, 2019 04:56 PM
sandman121383
Dec 22, 2017 04:08 PM
LeXcite
Jul 2, 2016 10:03 PM
