QM 8-leg Install help & tips
I have the new QM 8-leg about to be installed and I'm going to be doing it in the garage. But I do have some reservations about the install before I go through with it. The motor is out of the car along with the tranny so this will help with some of it as I can mate the tranny up to the motor before it goes into the car.
I did buy the clutch with the new TOB as well so this will need to be installed as well.
From what I've read online the instructions that come with the clutch are bad and they are in reverse, is this correct?
Is there any shimming that needs to happen?
Any help will be much appreciated.
No shimming needed on a new clutch. Install is easy and kinda self explanatory, just need 4 10mm bolts that are 2-3" longer to mount your hydraulic release bearing to the trans where the throwout bearing was.
EvoDan2004
56
Aug 4, 2012 09:24 AM
fightex
Jul 6, 2012 05:58 AM
2006GSR
17
Jun 5, 2012 06:46 PM
