DIY COP Coil On Plug Setup
Old Apr 6, 2018 | 02:37 AM
  #166
jingalalahoe's Avatar
Originally Posted by WelDun1
I have a question concerning a DIY kit. Does anyone have a pn on the Mitsu Male Coil Connector? Im under the impression that it is an OEM connector for other sensors etc on other model Mitsubishis. Any confirm this or a pn?
Sumitomo DL090-3 Male is what you need
http://www.cycleterminal.com/dl-090-series.html
Old Apr 10, 2018 | 11:38 PM
  #167
WelDun1's Avatar
WoW this is great! I have been searching for the past 3 or 4 days for any pn for this connector. Turns out that connectors are the hardest part to find. I did however know that they are OEM on Mazda RX8s, some Suzukis, and Nissans with SR20s, but finding the actual pn is a whole other story. Other than SpoolinUp, JD Customs & MAP, I wasnt even able to find a single Electrical Connector website that wasnt Alibaba or Aliexpress... So thank you!
Now if i can only find out which Suzuki, Nissan or Mazda models come with them stock! At this point its not even about the money, it never was, i just like having the information!
Old Apr 17, 2018 | 12:56 PM
  #168
sontoofly's Avatar
Thank you
Definitely a great writeup, I look forward to doing this myself
Old Mar 29, 2019 | 08:50 PM
  #169
mt057's Avatar
Originally Posted by 2006EvoIXer
Alternator is more likely than lead-acid battery.
Could you imagine if 30,000 volts can go through the battery? To get back to coil, would it go through ECM? I doubt the ECM will survive that. Or any other electronics that it can travel through. It just doesn't make sense. Let's keep this discussion logical and not full of claims. And I don't buy that spark is 30,000V at spark plug and then it changes to 12V (or some other voltage) as it goes through the battery.
Electrical potential is between two points. If the potential is galvenically isolated then the two grounds and voltage sources are separate. The voltage on one side has a different ground path and thus does not effect the other side (unless you screw up and cause bad ground loops). The voltage generated by a switching or alternating current at the primary side induces a voltage on the secondary side which value will depend upon the turns ratio. As, I am sure everyone knows an alternator and Tesla coil make greater voltage voltage from a low voltage source this way. The induced voltage on the secondary side will not jump across the barrier unless you exceed the voltage rating for the rated conditions, baring mfg error
If you were to cross the isolation barrier with a direct connection bad things would happen. Grounds are keep separate except for a point using a capacitor or resistor to allow for transient currents.
A pulsed power application like the spark plug, current will travel from its positive potential through the plug then into ground. Which immediately loops back around. It does not necessarily have to travel home first. Current may flow into and out of the ground plane and to the battery. The ground loops will determine available paths.
Sorry to necro post but this triggered me.
Old Aug 13, 2019 | 07:41 AM
  #170
Tommyfacekicker's Avatar
yesterday I test fitted my coils and they sit very low WITHOUT the mounting plate. I see that with the mounting plate my coils would sit kind of high off of the plug. is everyone else's like that? is that normal?
evo 9, 06 scion xa oem coils
Old Aug 13, 2019 | 07:59 AM
  #171
Biggiesacks's Avatar
I think thats normal with the toyota coils. If you dig into some of the how-to's I think its pretty common to stretch the metal coil that contacts the plug so that it makes a good connection.
While we are here though I can update the previous discussion on ground paths, knowing perhaps a little more now. Both sides of the transformer (ignition coil) Primary and Secondary are tied to chassis ground. So the return path is simply, head -> chassis -> secondary. I've been planning on adding a ground straight from the head to the coil harness to shorten that at some point.
Old Aug 14, 2019 | 03:02 PM
  #172
thanks for the feed back. I will be waiting to see your right up on the ground wiring.
Old Aug 5, 2021 | 10:07 PM
  #173
Abu Hakeem's Avatar
Dont know why my diy cop doesn’t work..it idles 5 sec then die..cant start it back..put back original coil car goes fine nothing happened..
im using k20 3 pins coil from honda and carefully checked all the wiring for any miss connection..all fine and good..
GTWORX.com
Evo 'For Sale' Suspension / Brakes / Handling
23
May 3, 2006 12:31 PM
evolution_4_all
West Region
185
Jan 1, 2006 11:59 AM
JSC Speed
47
Dec 5, 2005 01:16 PM
delivery
Jan 25, 2005 08:14 PM
nastea
Mid-Atlantic Region
Nov 29, 2004 01:50 PM
