How to: swap front sway bar on Evo 8/9 without disconnecting the steering rack
Old Feb 12, 2014, 04:50 PM
Terror Rising's Avatar
Either 8 or 6 will let you free. I say 6 as it's easier to get to and will let it drop straight down.
I never said thanks to you EGbeater, this how-to saved me the hassle of disconnecting the rack. Crossmember, subframe, whatever!
Old Feb 12, 2014, 05:54 PM
EvoM Community Team
golgo13's Avatar
Yeah, you beat me to it but thanks to you for the clarification and thanks to EGbeater for the write-up!
Old Feb 13, 2014, 11:55 PM
EvoM Community Team
golgo13's Avatar
So I got the subframe crossmember down as far as it will drop, but I'm having a hard time working the FSB out.
Which direction is easier, Passenger to Driver side? I've made the most progress going that direction.
Old Feb 14, 2014, 05:41 AM
That's the direction I did it, but there's nothing on the front end of my car right now besides the subframe. Just keep working at it and you'll get it. I ended up pushing the driver's side of the bar forward the further it came out and then played with the rotation to clear obstacles.
As a reminder, make sure you place the bar in the same orientation as you took it out when you do finally get it out. Had I not nested the old/new swaybars for comparison I probably would have put it in backwards. This was after me laughing about the "take a picture" comment.
Old Feb 14, 2014, 09:31 AM
EGbeater's Avatar
Agreed; I meant bolt #6.
I knew it was going to sound silly to recommend taking a picture to have a reference as to how the swaybar goes back in, but I didn't think to put bar down in the same orientation as it was in the car, and I ended up trying to put the new bar in the wrong way, so I was trying to save others that head-scratching/frustration.
I'm glad this thread has been useful to you guys.
Old Feb 14, 2014, 09:40 AM
EvoM Community Team
golgo13's Avatar
When I was trying to work it out it kept bumping up against the TC.
I'll try pushing the Driver side end forward towards the motor and see if that gives me the geometry I need.
Old Feb 16, 2014, 02:37 PM
EvoM Community Team
golgo13's Avatar
Well, that was fun.
Old Jul 17, 2014, 01:20 PM
Luckystryke's Avatar
Awesome write-up!
Old Sep 13, 2014, 05:30 PM
Raptord's Avatar
I just did this with a friend today following this guide. After hearing all the horror stories of how complicated swapping the FSB on our cars was, this turned out to go much smoother than I expected. Took us about 6-7 hours, but we were also installing the Cusco adjustable bracket and the endlinks were all seized up to the OEM one, so that added a solid hour of work.
The process in general went pretty smoothly, it just takes a while to go through all the steps but it's nothing overly complicated. We ended up leaving the downpipe connected to the rest of the exhaust and just lowered it from the front after unbolting it from the turbo and removing the 2 bolts of the first hangers.
The toughest step is #4 because of the extremely limited access. We removed the battery and had one person use a socket/ratchet from the driver's side of the engine bay, while another person was under the car holding the nut on the passenger side with a wrench.
Removing the bar was easiest by starting from the passenger side as there's less junk in the way there. Once the passenger side is out it's easier to wiggle and maneuver the bar to get the driver side out.
Thanks for the guide OP!
Old Nov 9, 2015, 01:44 PM
kyoo's Avatar
subbed... this may be just what the car needs but nervous to do it...
Old Dec 16, 2015, 08:27 AM
kyoo's Avatar
bumping this - would it be any easier with the front struts out of the car, or not really?
Old Dec 16, 2015, 03:04 PM
Raptord's Avatar
Just going off of memory here, and keep in mind I did it over a year ago, but I don't think it would be, I don't remember them being in the way.
Old Jan 16, 2016, 04:14 PM
joseph146's Avatar
i need to try this
anthonypazsd
134
Jan 19, 2024 11:48 PM
doncarbone
10
Sep 14, 2017 10:40 AM
DangerousDan
04-06 Lancer Ralliart How To Requests / Questions / Tips
54
Mar 13, 2017 01:27 AM
TronCarterIII
Nov 25, 2016 08:05 PM
k0lok0yboi
11
May 14, 2016 06:00 AM
Quick Reply: How to: swap front sway bar on Evo 8/9 without disconnecting the steering rack
