Simple 6 pot brake setup
Old Apr 23, 2014 | 07:53 PM
  #61
Grimgrak's Avatar
Someone def needs to get ahold of someone with a CNC to make some proper brackets then this swap would be legit!
Old Apr 27, 2014 | 08:11 AM
  #62
Ralliart004's Avatar
Veteran: Air Force
Can anybody verify the application of the srt8 rear calipers as a bolt on for our cars?
Old May 3, 2014 | 06:09 PM
  #63
sgtr275's Avatar
Please help me understand your math. When comparing piston volume, shouldn't all of the pistons you are replacing be considered?
Originally Posted by boostzealot
34mm piston diameter = 1.33858 radius of which is .66929
36mm piston diameter = 1.41732 radius of which is .70866
38mm piston diameter = 1.49606 radius of which is .74803
pi=3.1417 x (.669x.669) x 2 = 2.81220478 or just 2.812 sq/in of piston area if there were 4 34mm pistons
doing some math...
pi*r^2 *2 is for 2 pistons, not 4 as stated
So the evo caliper pistons are 46mm and 40mm. Using the equation above the evo calipers have
46mm piston diameter = 1.81102 radius of which is .90551
40mm piston diameter = 1.5748 radius of which is .7874
since we are only accounting for the number of these pistons on the car totally one can say that the evo has
(46mm piston) + (40mm piston)
1660+1254.8=2914.8mm/sq piston area for the evo caliper by calculation
for 1 caliper, you would want to multiply by 2 to make it 5837 mm^2 for one caliper and 11674 mm^2 to include both calipers you are replacing
(34mm piston)+(36mm piston)+(38mm piston)
907.09+1015.5+1133.5=3056.09 mm/sq piston area for the 17z caliper by calculation
This would end up being 12240mm^2 for a difference of about 565 mm^2
Seems like a significant difference
Old May 29, 2014 | 02:22 PM
  #64
TigOLDBiTTies's Avatar
awesome thread man thank you. the only thing im worried about is what kind of racing brake pads are offered for this type of caliper?
Old Aug 25, 2014 | 11:15 AM
  #65
jamesinger's Avatar
I really want to know how the rears will go on, so I am bumping this thread.
Also, with just the fronts, while tracking, I would like to know how this offsets the brake balance without upgraded rears.
Thank you for the write up!!
Update please!!!!
Old Dec 10, 2014 | 03:55 AM
  #66
rodrig.diaz3's Avatar
Really impresive Swap.
Im going for it.
2 questions.
Can i fit the 18Z MODEL, what is needed, 18 " wheels only ?
I want to install with metalic brake lines, do i have to made customs ones ?
Regards.
Old Dec 10, 2014 | 07:12 AM
  #67
polish_pounder's Avatar
Sub'd:
Can you please provide more pictures. and just to clarify rotors are the same size? but can be bigger? I think I missed that one.
Thanks,
Old Dec 10, 2014 | 08:15 AM
  #68
rossbots's Avatar
Brackets would be great... I need to get away from my RS setup and have some real brakes on the front.
Old Dec 10, 2014 | 01:06 PM
  #69
I agree with a bracket or that CNC'd part for after you remove some of the caliper haha
Old Mar 5, 2015 | 08:29 AM
  #70
Evolution7GSR's Avatar
any updates on this?
Old Mar 7, 2015 | 07:28 AM
  #71
Grimgrak's Avatar
Nope someone needs to let a vendor know there is demand for this.
Old Mar 7, 2015 | 12:59 PM
  #72
ZX2wv's Avatar
This is pretty awesome, I'm going to have to be on the hunt for some of these calipers now
Old Mar 7, 2015 | 09:32 PM
  #73
boostlogic's Avatar
If someone knows any shops or vendor that'll willing to build adapters like the ones they have s14's that'll be perfect. Similar to these
http://www.tf-works.com/tf-evo-8-9-b...n-s13-s14-s15/
Old Apr 22, 2015 | 06:46 AM
  #74
Anyone have any updates on this? I would love to do this conversion if someone would be able to provide a bracket to match them up to the stock Hubs?
Old Apr 22, 2015 | 12:59 PM
  #75
LetsGetThisDone's Avatar
the only way to build a bracket for this would be to use a larger rotor because the bolt holes just about line up. It would easier to buy an aftermarket radial mount caliper from Wilwood and build a radial mount bracket to bolt to the spindle.
