02 sensor removal!
Heat the manifold up around the sensor and see if you can get it to budge that way. You may have to cherry it to get it out but you run the risk of pulling the threads out with the sensor when you heat it. You can hit it with oil after heating to shock it and maybe break it loose. Be prepared to buy a tap to clean or remake the threads in the manifold if it's a real pita.
lostsoulsevo
10
Jan 6, 2014 08:35 PM
