Evo ix fuel relay
Old May 29, 2014 | 06:07 AM
rip's Avatar
rip
Evo ix fuel relay
Good day all,
Been experiencing an issue where my fuel pump does not come on sometimes and stalling after engine boggs down.
I've changed fuel pump and checked FPR.
Still unsure if i've solved the problem but in my quest, i've replaced the fuel pump relay and would like to share the part numbers and location of parts under the hood for anyone else who would like to do same....
car is a jdm evo ix mr
^that's the ACD relay - behind it on the firewall is the fuel pump relay
evo ix jdm MR acd relay number: MR 580182
^comparison of ACD relay on left vs fuel relay on right
old fuel relay on left vs new relay on right
Part number for old fuel relay:MN 122584
Part number for new fuel relay: MR 514694
I have not replaced the two relay switches at the drivers side yet - just want to see if i solved the problem with changing one of the relays.
thanks to Teknet of Trinidad for supplying parts and Silvermike for helping to troubleshoot in case it was MAF sensor.
Hope it helps anyone in the evo community when looking for parts...
Old Jun 18, 2014 | 06:09 AM
rip's Avatar
rip
Solved the problem.
It seems one of the fuel relays under the driver side compartment was on the way out or could not handle the increased current draw from the walbro.
As a result, the engine would tumble but no fuel to injectors since pump was not receiving power via relay.
The fix was to install a higher amperage relay (30Amp) in the same location.
I can't thank Mr. Beard (electrician) enough for helping to sort this out - he went through alarm system / harness etc.
See alot of ppl have the same issue- this might be a solution....good luck out there..
Old Jun 25, 2014 | 06:32 PM
tony gibson's Avatar
are you talking about the relay compartment under the dash by your left leg? I am having a similar issue.
Old Aug 6, 2015 | 04:59 AM
rip's Avatar
rip
now seeing this....jdm is RHD....so i'm thinking for a LHD - your fuse box/relays will be on that side as well...
let me know if you solved the issue please.
thanks
Old Mar 10, 2019 | 06:53 PM
theonlyherb's Avatar
Not to dig up an old thread but what part number did you go with for the 30amp relay?
Old Jan 31, 2020 | 07:54 PM
Apexsilver06's Avatar
Veteran: Army
Really could use that 30a part number!
Old Jan 31, 2020 | 10:42 PM
Nicholas Landis's Avatar
Good luck
Howd it go
Old Feb 1, 2020 | 03:49 AM
huzzle101's Avatar
Its right there in his picture and thread.
Lightsaber
Apr 4, 2018 10:02 AM
Corbin09
For Sale - Cars For Sale
Jun 3, 2013 02:17 PM
mitsuclipsegsx
34
Aug 30, 2012 03:33 PM
asubennett
72
Jun 19, 2012 12:21 PM
GraphitePunk
Apr 7, 2010 05:27 PM
