Help installing 3 aem gauges where to get the power for the 3 of them ?????
Old Jun 14, 2014 | 04:31 PM
evo9powerr's Avatar
Im gonna be installing aem wideband , aem boost and aem oil pressure .. Im wondering if i can get the power of the 3 of them from the cigarette lighter or it has to be from different places???? .. Ive always installed the gauges from the cigarette lighter before on other cars i dunno on this one.. Also can i install the ground of the 3 together from
The same place all
Of them ... Help is appreciate thankssss
Old Jun 14, 2014 | 04:42 PM
PaEvo's Avatar
Any 12volt power source that is turned on by the ignition switch (cig lighter) is suitable to splice into. I've run many gauges in series (one after another) on the same common power source with no ill effect. Also, the ground is pretty simple. All electronics in a car are connected to a common ground, the frame of the car. Find a ground and source it as you own. If that isn't convenient, which I've never not found a common ground, take sand paper or a dremel with a grind wheel, clean off paint, drill a hole in metal, and use a self taping screw to ground any electronic
Old Jun 14, 2014 | 05:38 PM
evo9powerr's Avatar
So i can use the the cigarette lighter for the 3 power and the same ground for the 3 pf them
Old Jun 14, 2014 | 08:44 PM
DanyLeduc's Avatar
Yeah pretty much.
Old Jun 15, 2014 | 06:11 PM
evo9powerr's Avatar
Also what is the best place to put my wideband sensor
Old Oct 21, 2014 | 03:54 PM
BEISSEN's Avatar
I had a issue with the Cig lighter get a pigtail Fuse and run it off the fuse box location. Solder and heat shrink all the wires. Get the Pod from a vendor that goes where the radio is or locate a Gruppe-S Panel. Their hard to find but worth it.
asdfasdf128
Apr 17, 2016 06:24 PM
Jacoby
18
Dec 20, 2011 08:55 PM
dL_EVO
Nov 12, 2011 11:36 AM
wiretap
Evo X How Tos / Installations
12
Feb 28, 2011 04:10 AM
rontam90
Canadian Forum
Nov 6, 2008 09:24 AM
