Evo 8 valve cover gasket install??
Old Dec 24, 2014 | 10:40 PM
djslik408's Avatar
I'll be replacing my gasket as i have a small leak and my gaskets arrived today. Can someone shed some light on how much torque i need to tighten the screws? In looking at the video, it is a very simple job to do.
Thanks in advance.
Old Dec 25, 2014 | 12:10 AM
twabtoxer's Avatar
I just replaced the gasket and the spark plug gaskets earlier today. I just hand tighten mine , I know I have seen the torque specs floating around here though
Old Dec 25, 2014 | 09:51 AM
heel2toe's Avatar
31 (+/-4) inch pounds.
https://www.evolutionm.net/forums/ev...cs-thread.html
Remember inch pounds not ft pounds. Oh and e very careful as you can crack it super easily. I loosen from the outside in and tighten from the inside outward
Old Dec 25, 2014 | 06:27 PM
twabtoxer's Avatar
Old Dec 26, 2014 | 08:57 AM
djslik408's Avatar
Thanks guys!
Old Dec 27, 2014 | 01:03 AM
djslik408's Avatar
this was a successful install. Tested and driven without any more leaks! Thanks everyone.
Old Dec 27, 2014 | 07:57 AM
JDMmontana's Avatar
Also as a bit of a technical tip, you can put a small amount of rtv on the corners of the gasket so it says stuck in the valve cover and doesnt fall off and get sandwiched between the head causing it to not seal correctly, i always do this, its hard to keep the gasket on and align everything with only 2 hands.
Old Jan 22, 2015 | 11:12 AM
Wellsfargo's Avatar
Thanks in advance.
Good afternoon Sir, I also need to do my valve cover gasket . Would you be able to share where you got the video?. Thank you
Old Jul 25, 2017 | 08:46 AM
rm4g3d0n's Avatar
Bumping this.
I replaced my gaskets, but haven't started it yet. Was wondering if there was any accurate way of tightening the bolts without a meter of some sort. Someone here said hand tightening it, but it that good?
Old Jul 25, 2017 | 10:37 AM
heel2toe's Avatar
Originally Posted by rm4g3d0n
Bumping this.
Is quoting yourself from 3 years ago allowed!? As mentioned work your way outward and just snug them up. It doesnt need to be exact science so just snug them down but dont give it the beans or else you'll crack it. I actually prefer to not use a torque wrench for my VC these days whenever I pull it.
Old Jul 25, 2017 | 12:48 PM
rm4g3d0n's Avatar
Yeah i know it's 31 in-lb, but i don't have anything to gauge it. Any way of doing it without a tool?
Old Jul 25, 2017 | 12:55 PM
heel2toe's Avatar
Yes, as I mentioned just snug them up with a ratchet. No need to really get them torqued to spec, just feel it out. Its not like its structural so I wouldnt be too concerned about it. But tight enough that it wont vibrate out but not too tight where you'll crack the magnesium VC.
Old Jul 26, 2017 | 06:32 PM
BoostinRS's Avatar
Thumbs up
420a-t
27
Aug 1, 2023 09:27 AM
Kraise
Feb 19, 2018 04:13 PM
ILuvJDM
May 2, 2014 09:33 AM
yitzac1990
Lancer Engine Tech
Feb 25, 2010 04:08 PM
StevenStarke
Nov 14, 2007 06:26 AM
