need Help removing front block cover
Old Jun 29, 2015 | 05:56 PM
asoom90's Avatar
Veteran: Army
Looking for some advice and how to remove the whole front block cover so I can swap it over to my new block. Any help with be greatly appreciated. Thank you
Old Jun 29, 2015 | 06:04 PM
kaj's Avatar
kaj
"Front block cover"?
Old Jun 29, 2015 | 06:05 PM
asoom90's Avatar
Veteran: Army
That's what i was told it was call. Sorry
Old Jun 29, 2015 | 06:58 PM
kaj's Avatar
kaj
No worries. Just trying to figure out which part you need. There's quite a few in your picture.
Old Jun 29, 2015 | 07:05 PM
asoom90's Avatar
Veteran: Army
I'm trying to figure out how to remove the whole front case and sepatine bellt tensioner. I already have brand new sprocket and front case gasket.
Old Jun 29, 2015 | 07:54 PM
kaj's Avatar
kaj
There's not really a "case". You have the oil filter housing, oil pump, water pump, balance belt/tensioner, crank pulley, etc.
Old Jun 29, 2015 | 11:54 PM
Jetech38's Avatar
It's just a matter of nuts and bolts. The serpentine tensioner comes off with 2 bolts, overcenter the pulley with a 1/2" drive breaker bar or ratchet. The gear on the crankshaft should pull off, after that the trigger disc, then the balance shaft gear. Water pump is bolts. Oil filter housing, bolts. Oil pump, more bolts.
With that said, it looks like you've got a bit of corrosion going on, so it may not be as simple as sliding cogs off. PB Blaster and a pulley removal tool should be added to your shopping list.
mantosride
Sep 25, 2009 02:19 PM
EvoAlex48
Jul 25, 2009 02:56 PM
dekfu1
Oct 14, 2006 11:22 PM
dekfu1
Oct 6, 2006 01:21 PM
NocturnalEVO
Aug 2, 2005 12:37 AM
