ATP 3071R Turbo Kits IN STOCK!!!
Old Apr 15, 2005 | 10:52 AM
  #91
A-SPEC's Avatar
Originally Posted by umiami80
Just asking cuz OTHER VENDERS stated that this kits exhaust housing limits WHP Up top
I am liking this kit though, I mean if you get it, make sure you have Buschur Racing PORT your exhaust manifold, just do it as it'll flow close to what a tuby will especially on pump gas. The Twin scroll will keep exhaust gas velocity up to keep it spooled.
I just want a GUARANTEE that this turbo will just bolt RIGHT into place, no banging water lines, no banging the fan or hitting IC pipes. Oil lines lining up and so on. And this is an off the Shelf Garrett?
The 380 WHP, what CAMS were used? Injectiors? FMIC? ANd on what dyno?
Yes. On the above post, that is the turbo kit in question. The only thing that is different is the upper boost tube and the 4" intake pipe to the turbo. Those are custom pieces and are NOT included with the turbo kit.
The turbo WILL bolt RIGHT into place w/o relocating a single thing. Everything lines up perfectly. No, it is not an off the shelf Garrett. The turbine housing has been custom made by ATP to bold up to the stock manifold. However, the trim and a/r are exactly the same as the off the shelf version.
With the 380 WHP, our Evo has Crower 262's, Greddy 660cc's, ARC FMIC and was tuned on a dynojet dyno. According to our tuner, our Evo should dyno 20 HP more on other dynos such as that from XS Engineering. Something about it being SAE corrected or something like that.
Like I said, 420whp on pump is defintiely do-able. It all depends on the tune and ECU. On our AEM EMS, we tuned VERY conservatively. Also, us CA guys only get 91. You might get 93 or higher where you live.
Francis@aspec
Old May 3, 2005 | 05:22 AM
  #92
Coolguy949's Avatar
Originally Posted by A-SPEC
I can personally vouch for this kit as we use it on our Evo race car. With proper tuning, it's possible to have a monster Evo with STOCK INTERNALS!
I think using this kit on a "race" car is stupid, why not upgrade to a high flowing manifold? The ATP kit is great for the street, but I dont know what person in their right mind would use it for a race application, especially time attack!
Yes, in a way the stock manifold is a restrictive piece with the GT30 series turbos. However, the restriction only comes into play around 600HP. Further research on evom will show that the factory twin scroll piece is one of the best you can find. Kudos to Mitsu for such a great design out of the box! Even Buschur on the 20g came to the conclusion that the Twin Scroll setup is very good and out performed his tubular manifold by quit a bit.
Yeah but the ATP kit doesnt utilize twin scroll, it just lines up the holes so the stock gasket works. The hotside is just one cavity that looks like twin scroll.
Old May 3, 2005 | 05:25 AM
  #93
Coolguy949's Avatar
660's work just fine with this turbo. We run 660cc's on our Evo and in my opinion, 660 is enough for 500whp. Any more than that and you run into injector control problems etc. that would require a seperate, more powerful, ECU. Also, larger injectors make it more difficult to tune for things like idle, decel. etc.
injector sizing isnt really subjective, you just gotta do the math. MAYBE 660 is enough on race gas for 500whp......we were running at 90% duty on our gt30 series at 525whp with 720's!
Old Sep 15, 2005 | 08:26 AM
  #94
htsai14752's Avatar
can you fit a 10.5 hotside on this turbo?
Old Sep 15, 2005 | 09:04 AM
  #95
I'mStock's Avatar
I think he's talking about using just an AFC with 660+ injectors. To get it to idle worth a **** you'd have to pull fuel like crazy, in turn screwing with your timing.... right?
Old Sep 15, 2005 | 09:09 AM
  #96
QuickEvo's Avatar
It would depend on the size of the track. Small technical track, I'd want a quick spooling turbo. Large track with big sweepers etc, I'd want the topend of a larger one.
Old Sep 15, 2005 | 09:46 AM
  #97
Jaylenospoolboy's Avatar
It's the hotside that bolts to the manifold. The hotside is the proprietary piece that makes this kit different.
You can mount the 10.5 hotside to your stock turbo and don't need to spend the $ on this kit.
Old Sep 15, 2005 | 11:31 AM
  #98
htsai14752's Avatar
what i mean is i know the atp kit is restrictive. is there any way to make it less restrictive and changing it into a twin scroll hotside
Old Sep 22, 2005 | 01:11 PM
  #99
I'mStock's Avatar
I'm pretting sure the A/R of the ATP kit is larger than a stock turbo's...
Old Oct 3, 2005 | 07:18 PM
  #100
ray3328's Avatar
Has anyone gotten this kit on their car? Has anyone tuned this kit with a falsh?
XTR Performance
16
Jun 5, 2013 08:16 AM
A-SPEC
Evo 'For Sale' Suspension / Brakes / Handling
43
Aug 29, 2010 06:14 AM
A-SPEC
Evo 'For Sale' Exterior Styling
82
Jul 18, 2008 05:00 PM
vigilante
Sep 27, 2006 01:26 AM
joEvo8
Feb 28, 2005 09:28 PM
