Agency Power BOV Version. 2
Knowing that the EVO has a very sensitive MAF which causes many BOV's not to work correctly, Agency Power turn to its design team to produce the first multi function and fully adjustable Blow Off Valve for the Mitsubishi EVO, 4G63, and other vehicles using 1.25 inch inlet and outlet flanges. Keeping the turbo spooled between shifts, holding boost pressure strong, and giving you adjustability is what the all new Agency Power Blow Off Valve offers you.
What makes the Agency Power Blow Off Valve above all others? The AP BOV is made in the USA and designed from the bottom up after analyzing the current market competitors. What we designed was a full T6061 CNC aluminum valve. The sleek body has a smooth round surface anodized with rich stylish colors in Stealthy Black, Show Silver, and Rich Red. The Agency Power text is engraved on the body next to the 50/50 vent plate. The outlet flange is removable and can also work as a full vent to atmosphere position. The base is 1.25 inches in diameter and designed to be used with the factory hoses in the factory position. The brass nipple on the side is ridged to ensure the vacuum hose stays secure and has no leaks. Continuing with style, the top of the valve has the trademark AP logo engraved on the triangle style top which adjusts the valves spring load. This is held in place by a diamond cut lock ring and O ring. The inside of the valve is operated with a piston and steel spring. The spring rate is manufactured to the correct rate for stock to aggressive boost levels. There is O rings inside to provide proper movement and sealing.
The Agency Power BOV is a fully adjustable, fully rebuild able, and a completely useful device. The BOV is designed to be used with several different setups. The valve can be set up to vent 100% to the atmosphere or 50/50. This is where 50% of the air is returned to the intake pipe and 50% is vented out. As well, this valve can be setup as a 100% recirculation valve like stock. The valve includes the return line plug as well. We recommend this valve for daily drivers to high boost race cars.
$230 Free Shippingwithin the 48 states
Available in polished, red, or black.
If i can have more than 15 people sign up i can sell them at $195 free shipping. if you are interested in the group buy, please leave a post with the color you want. i have tons of these in stock.
Questions? Orders? PM me or call me at 1.866.44.vivid ext 226
Jacky
Jacky
Who is still interested:
1. my04rs red
2. Thegame red
3. SilverCOEvo silver
4. EvoRhodeIsland red
5. heSOshAdy
6. danalo
7. rlazer5000
8. SuPeRNet
9. BYBYSTI black
10. SpedFrek red
11. kid evo8 red
12. Sam Shaw Polished
13. z_dorifto
1. my04rs red
2. Thegame red
5. heSOshAdy
6. danalo
7. rlazer5000
8. SuPeRNet
9. BYBYSTI black
10. SpedFrek red
11. kid evo8 red
13. z_dorifto
Originally Posted by SIC SIK SIX
comes with evrything i need to bolt up?
Jacky
Originally Posted by Evo8kid
not like its important..but ill ask anyways...how does it sound compared to other bovs?
Originally Posted by VividRacing.com
not as loud as an TXS RFL or an HKS SSQV, but very noticable. depending on your setting on this BOV will be the sound you get so anywhere between a forge recirc and a bit under the TXS RFL or an HKS SSQV.
Vivid Racing
EvoX 'For Sale' External Engine / Power
40
Aug 24, 2010 10:43 AM
Vivid Racing
May 2, 2008 11:48 AM
Vivid Racing
13
Jan 12, 2006 03:02 AM
Vivid Racing
Dec 21, 2005 11:51 AM
Vivid Racing
10
Jul 12, 2004 12:29 PM
