Pics of my engine bay after some minor work.....
Old Dec 6, 2004 | 11:47 AM
Karash's Avatar
yea that is super clean...I wish my engine could be re-routed like that.
Old Dec 6, 2004 | 11:53 AM
EVOMIZ's Avatar
Nice almost as nice as mine
Old Dec 6, 2004 | 12:22 PM
Karash's Avatar
WHere did you re-route the main harness...and more importantly how?
Old Dec 6, 2004 | 12:28 PM
cky3396's Avatar
nice pix, what camera you shooting with?
Old Dec 6, 2004 | 12:51 PM
sleet's Avatar
I'm gonna go get some of that paint and do mine up How many coats did you do and how long does it take to dry?
Old Dec 6, 2004 | 01:08 PM
Evoisdream's Avatar
Originally Posted by BADEVO
How did you route the long cable that runs across the top of the valve cover?
What other lines did you re route. Looks very clean under there.
wondering the same thing would love to make it look like that already did most but this /\
evoisdream
Old Dec 6, 2004 | 01:17 PM
Bobby12many's Avatar
Well, to answer a few peoples questions......
I simply unplugged the connectors and removed all of the clips that held the harness to he engine in any way. Then I tucked as much of the harness as I could in between the head and the fuel rail to keep the bulk of the harness unseen. I then turned the rear engine hoist tab downward, and tightened it to hold the harness well. I then used small Zipties to hold the rest in place. I should have done a writeup..... Its alot simpler than it looks.
Do you have to put anything on the pipe or shield before putting the paint on?
You should definitely sand the entire pipe with 120grit or there abouts until the whole surface is scuffed in a evenly disspersed fashion. I sanded with 80, then 220 grit, and put on a coat of rust-o-leum primer before I started painting. Taped off the ends and sprayed on 2 coats, about 15minutes apart, and let it sit for about 14 hours before I installed it. Turned ot perfect.
Lets see some pics Also, were you ever on Twinturbo.net? If so, you remember me?
Canon Digital Rebel. Iso 100 6sec exposure.
I did 2 coats about 15minutes apart. The paint I used dried to the touch in about 10 minutes and fully cured in about 10 hours. most paints should be golden after drying over night.
Old Dec 6, 2004 | 01:21 PM
evoisdream
Simply remove the bolt and tab holding the the cable and replace the bolt sans the tab back onto valve cover. Then its simply a matter of flopping the cable back near the Intake Manifold, and finding a spot to Ziptie it down.
Remember, the throttle cable is much like a mountain bike brake cable, it can be bent in a linear fashion a pretty severe amount, as long as kinks arenot present.
At first I had the cable ziptied to the STB, but I didnt like the way it looked. Now it is just ziptied to the main harness which was routed in a more hidden location along the back of the valvecover.
Old Dec 6, 2004 | 01:32 PM
Jakeg97's Avatar
looks good
Old Dec 6, 2004 | 02:00 PM
use2vtec's Avatar
Awesome pics man. Your car looks really clean. I was wondering where people were mounting their MBCs, I put mine in the same place . You have some pic taking skills!!!
Old Dec 6, 2004 | 02:09 PM
EVOtagger's Avatar
i would feel uneasy about rerouting and remounting the throttle cable, but thats just me...it doesnt really get in the way as far as looks are concerned, but if you run into some trouble with it, it can cause some problems...
nice work though
Old Dec 6, 2004 | 02:20 PM
insomniac_evo's Avatar
OT: what kind of camera did you use, that some nice high res pics...
Old Dec 6, 2004 | 03:34 PM
nice work though
I was worried about this also, but I have complete confidence in it holding up in this location.
I aso squirted a bunch of teflon cable coating for bikes into the cable on the TB end of it, just for added security concerning a sticking throttle
Old Dec 6, 2004 | 03:36 PM
Old Dec 6, 2004 | 03:39 PM
steveevo8's Avatar
very nice..... hopefully my bay will look like that soon wiht a few mods
