fender rolling pix :)
Old Jul 1, 2006 | 11:33 AM
Evo9"Miss Rose"'s Avatar
Awesome!!!!
Old Jul 1, 2006 | 01:00 PM
evo_dadi's Avatar
damn cal i didnt know devin's sporting an evo now also,how come not white like his suby
Old Jul 1, 2006 | 01:41 PM
EVOlutionary's Avatar
Originally Posted by Speed Element
unless you are running super crazy offset, this type of fender rolling will allow you to run up to 265 size tires on evo on 9-9.5" width wheels. anything bigger you will definitely warp the fender after awhile.
First off - nice rolling job! I cracked the **** out of my paint, but I did it in 30 degree weather and did not take my time on the first side.
I don't understand what you are referring to "warp the fender". What do you mean by that??
I am running both 285/30/18 Advan Neovas on 18x9.9+35 wheels, and 285/30/18 V710's on 18x10+32 wheels, and with the fender lip rolled all the way up it does not run anywhere on the inboard or outboard side of the fenderwell. The only place it did rub was the bolt/screw that hold the fender to the rear quarter panel right by the edge of the wheel well. Just shaved that off and moved it back about an inch.
EVOlutionary
Old Jul 1, 2006 | 01:53 PM
evo_dadi's Avatar
warping the fender happens when you try to push on the lip too much instead of rolling it.it happens more on the panel side when you try to force rolling the fender.i did that a little bit on the driver side of my car since i tried rushing it its hard to fix that area since its bonded to another piece inside.
Old Jul 1, 2006 | 02:01 PM
Speed Element's Avatar
yeah thats what i meant thanks evo_dadi
Old Jul 1, 2006 | 02:12 PM
occultworks's Avatar
How much does this tool cost? Can I pick one up at a Napa or something similar?
Old Jul 1, 2006 | 02:16 PM
boostedwrx's Avatar
good post and pics!!! Now where the hell can I buy one?!?!
Old Jul 1, 2006 | 02:25 PM
Revolver Ocelot's Avatar
Hey Cal, do you think a slight pull would be hard on the Evo's rear quarter? Ive never seen it done before.
Old Jul 1, 2006 | 02:30 PM
tirerack sells this tool. you might want to give them a call its about $200
Old Jul 1, 2006 | 02:31 PM
contact Tire Rack
Old Jul 1, 2006 | 02:33 PM
i think its do-able but would be hard to make it "perfect" as some parts of the quarter panel might start showing creases.
Old Jul 1, 2006 | 02:36 PM
Spooldyou's Avatar
damn it where was this when i needed it !
Old Jul 1, 2006 | 06:26 PM
boostedwrx's Avatar
contact Tire Rack
Cool thanks!
Old Jul 1, 2006 | 06:31 PM
mitsuorder's Avatar
Basically, I heart Cal for putting up pics. You've really been a huge behind the scenes support for this community from day one
Old Jul 1, 2006 | 07:04 PM
RazorLab's Avatar
If you push too hard on the fender it will cause warping of the fender. I did that on my car a little bit. You can only see it in certain lighting however.
You can see it in this photo a little:
http://www.norcalmotorsports.org/use...o062406_02.jpg
This will fit 275's no problem though.
