ANOTHER 35r 56K No Way!
Old Jun 23, 2007 | 10:33 PM
  #226
PharmEcis's Avatar
Originally Posted by 34Turbo
Thats why JE and Ross makes drop in pistons. BTW, as far as I know Jrod at Buschur built his motor the same way
While I might just have a meager grasp of automotive technology I've seen my fair share of drop in piston replacements. Every stock bore size piston that is aftermarket usually tries to compensate for the cylinder wall to piston clearance difference demanded with forged pistons. There are numerous things that need to be kept in mind when factoring this compensation. How old is the motor and how much has the normal wear and tear enlarged the bore? Out of roundness of the cylinder bores. Variance from bore to bore in the same block. Variance between blocks. We are talking about values measured in .000x - .00xx of an inch.
Of course new ACL rod bearings were used. Why would I need main bearings if thats what you meant? There was nothing wrong with the internals.
I never implied you needed main bearings. You swapped rods so the crank should have never come out. It would probably have been nice to replace the main bearings while in there as it really wouldn't have been much more work. So what prompted this upgrade? If I'm following your thread properly you just had this kit installed and tuned and made good numbers. Now all of a sudden you added rods and pistons to your motor and retuned. If someone has a car that is not damaged and they just got a multi thousand dollar job done, I'd think they'd want to enjoy the car for a little bit before dropping another couple of thousand on the car immediately don't you? But hey I guess you ran into some spare cash and figured you'd spend the money now so you wouldn't have to pay later right? Deja vu might be in your future.
I wonder if you would run a Stratus in a little bit.
Old Jun 23, 2007 | 10:36 PM
  #227
34Turbo's Avatar
Originally Posted by JordanS4
My 333/341 on a cooler day (before cams) was on 25 psi, not 30. Also, your car blew a head gasket, and mine hasn't. What did all that TT power run on the track?
I blew a head gasket due to a clog in my alky line. I'm not going to lie, it could have been much worst. I run the car on the street like you would run it at the track though Run alky long enough and you'll learn that you have to pay to play.
  #228
JordanS4's Avatar
Yes, what a car is theoretically capable of based on HP/TQ is different than what it actually does based on the 1. the driver and (assuming same conditions for the runs) and 2. which car is better suited for its power in terms of gearbox, tires, powerband, etc... Capable = perfect world, Actually = results. I'd expect your car to trap near 130, if it doesn't, we can go from there.
I'd like to see track numbers from your car, thank you for being logical and I don't want you to break anything else, I'm fine with seeing a trap speed to match those dyno #'s.
Old Jun 23, 2007 | 10:39 PM
  #229
JordanS4's Avatar
By the way, I put the alky controller in limp mode for a week on accident, ran it hard, and thanks to the well tuned low octane map hardly noticed it was off. I'm at almost 3 months with the alky now. No troubles here.
Old Jun 23, 2007 | 10:43 PM
  #230
34Turbo's Avatar
I decided to add pistons, rods, and aem ems because Peter/Brad adviced me that not doing so with a 4'' intake on the stock MAF, 1000cc injectors on a stock ecu was very unstable. Also, he adviced me that building the motor while it was in prime condition was logical and the stresses at the power levels I wanted + alky factor would at one point would cost me twice as much. Oh and the drivability was ****ty on the stock ecu. In essence I did the rods and pistons because I want to push 600 or until the fuel pump maxes out on c-16
Old Jun 23, 2007 | 10:45 PM
  #231
GT35REVO8's Avatar
from what ive been following up on this drama...im on jordans4 side
34turbo-ok cool you got 524awhp...thats great...put you money where your mouth is and run 10s....maybe you have i dont know...i mean for christ sake you have a evo with CHROME WHEELS and EVOM on your intercooler( i mean evom is cool and all but come on man)
and 524awhp is nice but ill guarantee my car will do that with just 117 and 28psi...and i trapped 123mph on 92 octane,22psi and stock clutch with out launching one bit...lets see some traps/times
Old Jun 23, 2007 | 10:46 PM
  #232
memo3's Avatar
Damn, too many posts for a saturday night when you guys should be clubbing
  #233
JordanS4's Avatar
The 524 was one run correct? What were the "near 500" numbers after you detuned it? Honestly, just wondering.
Old Jun 23, 2007 | 10:47 PM
  #234
JordanS4's Avatar
34turbo-ok cool you got 524psi...thats great...put you money where your mouth is and run 10s....maybe you have i dont know...i mean for christ sake you have a evo with CHROME WHEELS and EVOM on your intercooler( i mean evom is cool and all but come on man)
Old Jun 23, 2007 | 10:48 PM
  #235
34Turbo's Avatar
I'll run 10s if you promise to pay for my tranny/TC. However I will run it to show the trap speed just to end this debate. Its actually "MOVE>" when you see it in your rear view mirror
Old Jun 23, 2007 | 10:49 PM
  #236
GT35REVO8's Avatar
ill pay for your tranny/tc if you lose those gawd ugly wheels and respray your intercooler
Old Jun 23, 2007 | 10:50 PM
  #237
34Turbo's Avatar
524/400 corrected as the car sits in my garage. I lost torque due to lower psi.
Old Jun 23, 2007 | 10:51 PM
  #238
GT35REVO8's Avatar
did you ever do a straight pump 91,92,93 octane dyno reading?
  #239
PharmEcis's Avatar
Looks like either we are too young to get into a club or we are too old and we talk about nights like that as "the good ole days".
Old Jun 23, 2007 | 10:53 PM
  #240
JordanS4's Avatar
After the AEM?
