ANOTHER 35r 56K No Way!
Old Jun 22, 2007 | 09:29 PM
  #196
34Turbo's Avatar
Well just added AEM EMS, Ross drop in pistons, and Eagle rods to the mix along with one step colder plugs and hks dli ii. The car made the same power with only 29psi!!! I told Brad to stop at that point. In a couple of days we will be doing the c-16 tune. Lets see where the walbro could take me before maxing out
Oh, in case people are wondering the car pulls like a raped ape...
Old Jun 22, 2007 | 10:07 PM
  #197
Ultimate CC's Avatar
unique
Old Jun 23, 2007 | 02:07 AM
  #198
memo3's Avatar
Finally it is done I need a ride in it. I don't wanna imagine how hard it will pull with alky, now my pump gas will feel slow hehe
You guys were tuning late again?
Old Jun 23, 2007 | 05:23 AM
  #199
Planet Evo's Avatar
Originally Posted by Galant VR-4 #34
Actually the wheels do look much better in person Congrats on the build and numbers, I guess Brad can tune a car afterall Actually he is the one who tuned my GVR-4 (11.20@126.54 3 years ago). . And no they are not a jiffy lube for me, They do so much I dont know where to start but the easiest way is to say that AMS Chicago does the engine tuning and provides parts and overall support. VIP does all the work on my car from suspension mods and tuning, to trans and clutch work, to racing mods to keep my car competetive with the big boys. They have even come to a few races to support me as my crew. Plain and simple, if they didnt do a great job, I wouldnt use them or have their name on my car. I would recommend them to anyone without hesitation.
Marty
So we have oil change, clutch and suspension mods? What suspension mods? What is the tuning thats done?
I have it highlighted for reference.
Marty Lets be serious. Its and AMS car. Either way your half the reason the car does well.
Old Jun 23, 2007 | 11:07 AM
  #200
PharmEcis's Avatar
So what you are saying is that you bent a rod or cracked a piston and instead of doing a proper engine build you ghettofied it? I bet the company working on your car suggested the drop in piston replacements and your block probably never came out of the car eh? I mean it took 6 months for the machine shop to turn around a head so there is no way in heck they already took possession and turned around a shortblock assembly is there? Hopefully you guys at least ran a ball hone through the bores before dropping in those rod/piston assemblies and gapped the rings right. Were the bearing clearances checked with some plastigauge on reassembly? New bearings did go in right?
Funny how some people and companies don't know that forged pistons require a looser clearance than cast pistons. Forged pistons can take a lot of abuse but that is because they expand under heat. So you are now running forged pistons in a block that was machined for the stock cast pistons. Welcome to a short lived engine build as you WILL have problems down the road.
Old Jun 23, 2007 | 03:53 PM
  #201
evovin's Avatar
nice!!!
Well, finally my car is completed!! After 4 months of issues with a blown head gasket, starter issues, lost parts etc... its put back together thanks to Martin and his awesome crew at VIP Garage in Sterling, VA. I will have the car tuned by Brad at ISP tomorrow to see how much power it makes. Until then enjoy the pics
MODS:
Engine:
VIP Custom Gt35r Kit w/ Custom Headers and DP
VIP Custom Intake w/ HKS RS Filter
44mm Tial Wastegate (Dump tube coming out the passenger side bumper )
HKS SSQV
AEM EMS
1 Step Colder Plugs
HKS DLI
ARP Head Studs
New Stock Head Gasket
Mahley Spring/Retainers
Ross Pistons
Eagle Rods
Snow Performance Alky Kit
Precision 3.65'' IC w/ Custom UICP/LICP
Powerflex Front Engine Mount
Walbro FP
AEM Tru-Boost BC
RNR Cat-Back w/ HKS Ti Muffler
Precision 1000cc Injectors
Tranny:
Spec Stage 3+ Clutch
Stock Tranny/TC
Handling:
BC Inverted Coilovers
JIC J-Force 07 17X9 +30
255/40ZR-17 BFGoodrich g-Force T/A KDW 2s
Cusco Type II Underbrace
Ray Lug Nuts
Rear Fenders Rolled
Interior:
AEM Tru-Boost EB Gauge
AEM Oil Pressure Gauge
AEM Oil Temp Gauge
AGX Wideband (Ugly as hell)
Greddy Shift Knob
Greddy TT
TomTom One Nav
Panasonic Head Unit w/ MTX Amp and 10'' Woofer
Exterior:
Chromealusion Painted Evo IX Badge (by Gary Best)
RMR Air Hood Scoop
CF Valve Cover
APR CF Rear Diffuser (On its way )
THIS GRAPH SHOWS THE POWER MADE ON THE STOCK ECU. THE CAR MADE THE SAME POWER (LITTLE LESS) TORQUE ON AEM EMS WITH LOWER BOOST (29PSI)
Old Jun 23, 2007 | 03:56 PM
  #202
BostonEvo's Avatar
Its the o2 Dump =)
  #203
badstainless's Avatar
I love how it says EvoM then Move! heheheh
Old Jun 23, 2007 | 09:14 PM
  #204
34Turbo's Avatar
Once again you are WROOONG
I'm sure you can call up Ross and take that reasoning up with them. The rings were slowly grinded and measured continuesly to match their required specifications to be dropped in to the shortblock, and the specs were set to make them pretty much loose as a goose. Thats why JE and Ross makes drop in pistons. BTW, as far as I know Jrod at Buschur built his motor the same way Of course new ACL rod bearings were used. Why would I need main bearings if thats what you meant? There was nothing wrong with the internals. You are bringing up a bunch of elementary points to TRY to sound knowledgable. Understandable, and you make some valid points but you can sleep easy buddy. I dotted all my "i"s and crossed my "t"s. Dishing out the money to have a fully built motor was not an issue for me. If it was necessary I would do it. Hell if it ever becomes necessary I will do it. You have a great day sir Oh, and call me when there is a DTM evo that can run me. I know you guys are still looking
Old Jun 23, 2007 | 09:35 PM
  #205
34Turbo's Avatar
Dude, Nick give it up or just leave it out of my thread. First spit out a couple of respectable street cars that can run hard and run period, then talk smack about other shops. I don't know what you are trying to prove with VIP or ISP. What do you have to show for in the area? The shops mentioned above have a lot more respect in the area than you guys could ever wish for. You have already ruined your reputation in DC, try not to do it nationwide Move to Florida or something and start over. I'm not being mean, I'm just stating the facts. I'm looking out for you bro. All we do at meets and events now is make fun of DTM! How much ammo do you want to give us?
Old Jun 23, 2007 | 09:40 PM
  #206
VIPGarage's Avatar
thanks for the call with the info today bro. glad she is doing so well. call me monday so we can setup the other stuff we talked about.
Marty, thanks for the kind words but i'm not worried about trying to validate us to the koolaid crew. All those nice plaques and trophies on your car at hyperfest today are all we could ever need.
Old Jun 23, 2007 | 09:41 PM
  #207
JordanS4's Avatar
What is this "Oh, and call me when there is a DTM evo that can run me. I know you guys are still looking " crap?
The first time Carlos suggested you race a DTM car he clearly stated you should race David Brandt. He has a simple GT35R kit but will gladly run you. I don't want to speak on his behalf but I'm sure he feels the same way. Please don't make Carlos race you in "betty" either, that would be just plain embarassing.
Old Jun 23, 2007 | 09:45 PM
  #208
JordanS4's Avatar
What did you do for him to help him get those plaques? Still not a straight answer...are you embarrassed? Honestly, I'm just curious at this point. I don't understand why you can't just say what you do for Warrtalon and Marty. Simple question with an apparently complex answer.
Old Jun 23, 2007 | 09:50 PM
  #209
34Turbo's Avatar
As for Dave, just tell him I'm ready when he is. Is race gas allowed? I'm cool if not. We could set up Memo's car on some race gas and that will be that for "betty" We roll deep if you just want to talk about other people's cars While we're at it, I'll run your S4 too. Trust me, it will be embarrasing...
BTW, Carlos owns betty but does he even drive it?? It sits at DTM for free work and parts which he pays for. Plus its a track car. Where are you going with it. My car is a street car so is Memos but I think we all know what is going to happen when a 700awhp Buschur car like Memo's runs the "betty"
I know I'm being a dick but here is the simple fact. DTM DOES NOT HAVE THE FASTEST EVO IN THE AREA AND PROBABLY NEVER WILL!
Old Jun 23, 2007 | 09:55 PM
  #210
VIPGarage's Avatar
like i said i am not worried about trying to justify anything to anyone from the koolaid crew. specially not some typical teenage fanboy. Marty said it all. We'll just work on winning more and more races. Seems like we've been doing that just fine.
