ANOTHER 35r 56K No Way!
Old Jun 12, 2007 | 04:12 AM
  #151
EVO8LTW's Avatar
Originally Posted by 34Turbo
Well the wait is finally over. Dyno graph posted on the first page... 31psi 524awhp/447awtq, stock head (except for retainers/springs), stock ecu, stock bottom end, stock intake manifold... enjoy
Thank you Brad @ ISP for not blowing up my motor and Mike @ AMS (MD) for helping out with the tune!
Nice numbers (and I still like the wheels). How does it feel on the street compared to your old setup? What role did Mike play in the tune?
Old Jun 12, 2007 | 04:43 AM
  #152
Torre from Va.'s Avatar
Nice Turk, Let me know when your ready to get spanked on the streets
Old Jun 12, 2007 | 05:38 AM
  #153
VIPGarage's Avatar
glad you got the numbers you wanted bro.
Old Jun 12, 2007 | 06:14 AM
  #154
34Turbo's Avatar
Originally Posted by 04WWRS
Congrats Cem! I hope to join you in the 500 club come Saturday.
What cams are you running? I don't see any in your mods list.
Stock cams. I have a few more goodies going into the car
Mike helped us set some of the values for the injectors on ecu flash since we didn't have a base map for the stock ecu+1000cc inj.
Always ready buddy. I must warn you though, I have a couple more goodies and maybe an extra power adder going on
Old Jun 12, 2007 | 08:28 AM
  #155
derangedazn's Avatar
Awesome Cem...Sweet numbers.
Old Jun 12, 2007 | 09:31 AM
  #156
thegreatwall's Avatar
Nice car and intercooler.
Old Jun 12, 2007 | 10:16 AM
  #157
V.8MR's Avatar
Why do your AFR's fluctuate so much?
Old Jun 12, 2007 | 11:55 AM
  #158
ISPracing's Avatar
Atlantic Mike gave us some injector latency values to use. Thanks Mike! We normally don't try and run 1000ccs on flash cars nor will we do anymore, typcially we move to a aem system at this point as it has much more resolution and at these hp levels the maf is nothing but a restriction. Turns out, the problem we were having with the car loading up on fuel at idle ater blipping the throttle wasn't a latency issue but a Vent to atmosphere issue. Which normally is isn't that bad with smaller injectors, but with 1000cc's the phenomenon is amplified.
The fluctuation in the AF is from the alky system. It isn't a linear curve and once you turn up the boost it requires tweaking the fuel curve all over again. We don't really advocate a foriegn fuel source outside the cars EFI system. But it's the latest craze and the hp is adictive so we do what the customer wishes.
Old Jun 12, 2007 | 12:25 PM
  #159
I agree with Pete, That's why when I dynoed my car it was on straight pump & has aem.Then again that's how I've done all my cars. Either straight pump or straight C16, no mixing at all. As for Cem it's his car whatever just my .02 I personally wouldn't have done it that way, he's the customer...... good number again, though.
Old Jun 13, 2007 | 10:09 AM
  #160
version 2 beta's Avatar
I'd like to see you and dave run a couple times
Old Jun 13, 2007 | 01:21 PM
  #161
04WWRS's Avatar
I wanna play too...
Old Jun 13, 2007 | 01:25 PM
  #162
JordanS4's Avatar
Me 3 just give me a week or two!
Old Jun 13, 2007 | 02:43 PM
  #163
I just wanna videotape.
Old Jun 13, 2007 | 03:32 PM
  #164
dxbevo9's Avatar
nice
Old Jun 13, 2007 | 05:04 PM
  #165
Warrtalon's Avatar
Most people can't feasibly run C16 24/7, but it's no problem to run 93+meth 24/7. I'd much rather have 524whp w/stock ECU than 434whp w/standalone on the same turbo. A lot less money, less hassle, and way more power. There are others making 580-590whp on the stock ECU, so it's not a big deal. AEM EMS is better, but it's not required.
