Possible to remove taillight lens w/o dremel?
Old Nov 1, 2007 | 09:47 AM
OneillEvo's Avatar
Used the search function to no avail, is it possible to remove the tail light lens without using a dremel? Such as using a heatgun and carefully prying it off.
Old Nov 1, 2007 | 11:03 AM
ohEVO18's Avatar
bump cuz im wondering the same...if not i'll just opt for the DEPO's
Old Nov 1, 2007 | 11:13 AM
OneillEvo's Avatar
I was gonna go with Depo's too but I got a hold of a extra pair of tails for dirt cheap ($50) so I am just gonna open these up.
Old Nov 1, 2007 | 11:29 AM
insomniac_evo's Avatar
bake it
its so damn easy
pre heat the oven to 400F, after it beeps, turn the oven off and put the light in
make sure you take out all the bulbs
wait for about 5-7 minutes and try prying them off
Old Nov 1, 2007 | 11:44 AM
lightingevo03's Avatar
I used a heat gun and a utility knife worked awesome.
Old Nov 1, 2007 | 11:51 AM
04KWAK636's Avatar
damn seems like alot of work..
Old Nov 2, 2007 | 05:01 AM
ohEVO18's Avatar
do this for the tails? I know that the headlamps work like that, but I have been told a few times that the tail lamps have to be dremeled apart...If thats the case, these bI^(#es aer getting done this weekend...
Old Nov 2, 2007 | 05:28 AM
Evoz's Avatar
Lightingevo03 hit the nail on the head just buy a heatgun. it's the safest way to do this. The oven works but things can go bad fast with that option, i know from experience with other cars. if you choose to do the oven method just be very careful, you could end up with deformed tails...
Old Nov 2, 2007 | 05:32 AM
nasty8evo's Avatar
baking them really works..!
Old Nov 2, 2007 | 05:33 AM
eve-slow's Avatar
You will have to use a dremel, knife, or some kind of blade. The tails are definetly harder than the heads. The adhesive is much harder.
Old Nov 2, 2007 | 05:43 AM
ohEVO18's Avatar
sweet....well it looks like I have a weekend project aside from painting my buddys BBs on his STi
Old Feb 26, 2021 | 10:59 PM
BabyLancerFlex's Avatar
Clarification on this possibly??
So sorry to bump an ancient thread But I only know two answer and I'm wondering if there's a definitive answer on this? I don't want to dremel but we'll buy one if need be, I'm looking to retrofit a pair of my tail lights and if it says easiest baking it without melting the housing that sounds a lot easier than dremeling.
Old Mar 2, 2021 | 11:38 AM
driven168's Avatar
I have baked many head lights and tail lights. If applicable, you will have more difficulty convincing the gf or wife to let you put a headlight in the oven. Just start low, like 200-250 degrees and try prying it. If it doesn't pry, pop it back in the oven and repeat until the two halves separate. Be brave.
*edit*. Don't rest the headlights or tail lights lens side down on anything if possible. They scratch so easily it's not even funny.
SS2EVO
Nov 2, 2012 08:16 AM
Gooseman396
Aug 26, 2010 08:49 PM
quik-viii
Feb 4, 2010 10:58 PM
initialDRacer
24
Nov 18, 2005 09:15 PM
Chris@nolimitmotors
Jan 18, 2005 05:29 AM
