My Ongoing Build Thread, Thanks to Force Fed Perf., Spec Ops., MAP, Sparktech, etc...
Old Feb 10, 2011 | 05:15 PM
  #421
MJ23FE's Avatar
Can't wait to see what you picked up! BUY BUY BUY BUY BUY BUY BUY!!!
-Jalal
Old Feb 10, 2011 | 11:25 PM
  #422
06MREvo's Avatar
Alright guys finally some updates!!
Polished Toxicfab Cam Sensor Shield...
Large Hose fitting which will replace the front right valve cover fitting...Black 90* 6-AN fitting that will thread onto my rear STM fitting and delete the PVC valve...And the 4 things in the plastic bag are check valves...
TCC Coated Toxicfab manifold & Dump!
Synapse DV!
Samco intake with ETS Recirc pipe!
Got a box from STM the other day and when I opened it this is what I saw...haha...
Kiggly HLA...
DEI Black Heat Wrap & Ties which I will use to wrap my downpipe...DEI Titanium Turbo Blanket...
DEI Black Silicone Spray...New OEM Exhaust manifold studs...New OEM Injector O-rings...2 New OEM Oil Return Line gaskets...New OEM Oil Cap with Amsoil sticker...STM valve cover fittings!
A little more weight reduction...driveshaft tunnel heat shield...Hard EGR line...coolant overflow...Also pulled a bunch of other misc crap out of the engine bay and threw it in the box...
More updates will come...I've been doing some minor wire tucking/cleaning up the engine bay, Power Steering Cooler tube delete, Rear Wiper Delete...Toxicfab Coolant Overflow, Toxcifab Oil Catch can, Toxicfab Master Cylinder Brace...I am looking into an even lighter battery, Braille 11.5 lb battery & I will be making myself a new battery tray.....Valve Cover will be getting power coated and will hopefully be buying a new turbo before the end of the month!!!!
Old Feb 11, 2011 | 04:05 AM
  #423
vmrevo9's Avatar
Veteran: Air Force
looking good! after I installed the wrap and sealed it, it stunk for about 3 weeks and smoke was coming out of the engine bay lol. it was pretty interesting
Old Feb 11, 2011 | 06:18 AM
  #424
detroit pistins's Avatar
nice looking parts BJ! hey is the synapse flanged the same way the tials are?
on the heatwrap, one trick I have used is to boil the wrap prior to wrapping so it expands a lil, then contracts as it dries.
Old Feb 11, 2011 | 07:03 AM
  #425
GG06MR's Avatar
What are you using for the rear wiper delete? That's something I've wanted to do for many months now, but I've yet to find a clean solution.
Old Feb 11, 2011 | 10:18 AM
  #426
06MREvo's Avatar
Sweet...looking forward to that...shipping your bov in a little bit...
Thanks for the wrapping tip...Yup Tial flange, actually cheaper then the stock flange...
I think I am going to try out this plug that n1nj4 m0d3 posted pics of...
https://www.evolutionm.net/forums/ev...ml#post9066057
Old Feb 11, 2011 | 10:42 AM
  #427
GG06MR's Avatar
Sold! Any chance you'd be willing to PM me how you order that plug and any other necessary stuff for the install?
Old Feb 11, 2011 | 11:13 AM
  #428
06MREvo's Avatar
PM sent...
Old Feb 24, 2011 | 01:13 PM
  #429
Most-Wanted's Avatar
Love the updates... Car is still one of my favorites....
Old Feb 24, 2011 | 01:23 PM
  #430
badev0's Avatar
Last time I ordered from STM I received a bunch of starbursts
Nice parts!
Old Feb 24, 2011 | 01:52 PM
  #431
06MREvo's Avatar
Thanks Brian...It has been a long and interesting year with the car...been trying a bunch of different parts, some I liked, some I didn't...I am glad I now have the knowledge to comfortably tune the car myself...I am excited for this year, especially working with Collin and the amazing fab work he does...I am still looking forward to you posting another build thread with a new evo or Lana back...
Nice parts!
haha...I think there has only been one time I didn't get any snacks in my package from STM...I should have more updates tonight!
Old Feb 24, 2011 | 01:58 PM
  #432
Countrystrong11's Avatar
I didnt get any candy last time i ordered from them
Old Feb 24, 2011 | 02:40 PM
  #433
Thanks. I havent seen Fab work like Collins in a very long time. The evo community needed someone like him bad Seems we are both learning alot this year Another chapter closed and a new one just starting. Keep up the great work.
Old Feb 24, 2011 | 06:11 PM
  #434
Turboshrek's Avatar
Great thread!
More info on these please!
Old Feb 24, 2011 | 08:47 PM
  #435
06MREvo's Avatar
Originally Posted by Turboshrek
Great thread!
Those are check valves for my catch can setup...The PVC valve is known to leak under boost, so if I was keeping the pvc valve, which I am not, one of these would be put in the vacuum line from the pvc valve leading to my sealed catch can...Then another check valve would be put in the other vacuum line going from the catch can to the intake manifold nipple. Check valves are put in so that pressure does not build up in the intake manifold...
