My Ongoing Build Thread, Thanks to Force Fed Perf., Spec Ops., MAP, Sparktech, etc...
Old Dec 31, 2010 | 10:40 PM
  #376
06MREvo's Avatar
Happy New Year everyone!
Old Jan 2, 2011 | 04:54 PM
  #377
tscompusa2's Avatar
not sure how i missed your build thread, but how comes you had to add these braces?
very clean evo also.
Old Jan 2, 2011 | 05:47 PM
  #378
06MREvo's Avatar
haha well I didn't have to add them...Just like a lot of other things we don't have to do to our cars but we do...Before installing these the front end toe was always off a little bit...after installing these the toe came out perfect...I could actually feel the front being slightly stiffer after install too...Unfortunately I haven't had the car on a road course or autox event since installing them...Jim (jplgsx) is the head tech at a performance chassis shop in Cary, NC and he was the person to turn me on to these...He has a lot of track time at VIR and other tracks and he said they were probably his favorite chassis mod for the front end...
Old Jan 2, 2011 | 06:51 PM
  #379
BoostedFury's Avatar
Long road with your evo. Nice builds.
Old Jan 2, 2011 | 10:22 PM
  #380
tscompusa2's Avatar
ah ok nice. ya im sure that would make a hell of a difference.. its stiffening everything up.
Old Jan 8, 2011 | 08:47 PM
  #381
06MREvo's Avatar
Alright guys...some updates...Been taking my time and having some fun with the car while tearing into it over the winter...
BBK Full off the car and boxed up read to ship to the new owner!!
As you can see, turbo is off, valve cover off, and a nice chunk of the harness pulled out and set to the side...I plan on attempting to hide/tuck as much of the harness that I can...All of the harness that runs along of the top of the valve cover and over the intake manifold will be hidden underneath the manifold...
Valve cover off...I will be deleting the PCV valve and the breather on the right...I will be sending the valve cover to Collin @ Toxicfab and he will be drilling out holes and welding in some large fittings for relieving maximum crank case pressure...After Collin welds in the fittings the valve cover will be going to TCC to be powder coated wrinkle black...
Also you can see I pulled that ugly plastic coolant overflow out. Collin @ Toxicfab will be making me a smaller, much better looking overflow that I will mount in the same location...
Here is a box of random brackets and other crap that I have pulled out after around 2 hours or so of pulling the harness out and whatnot...After weighing the car at the E-town event and saw it tip the scales at 3350 with me in it, I realized I need to start working on some weight reduction...I know some of you may think pulling stuff like this out is stupid but every little bit helps...I also plan on climbing under the dash and removing miscellaneous brackets and whatnot that don't need to be in there...
Old Jan 8, 2011 | 09:01 PM
  #382
MJ23FE's Avatar
Good **** dude! We should def get together sometime so that I can check out the car....even if it is on jack stands!
-Jalal
Old Jan 8, 2011 | 09:07 PM
  #383
ToxicFab's Avatar
Looks good bro! Looking forward to doing a make over on your car!
Old Jan 8, 2011 | 09:23 PM
  #384
06MREvo's Avatar
-Jalal
Sounds good man! Next Friday I have Hernia surgery and I'm out of work for 3 weeks so Ill have a lot of free time! haha...
Hell yeah man! I definitely enjoy throwing ideas back and forth with you. Looking forward to having an engine bay filled with Toxicfab products!!
Old Jan 8, 2011 | 11:13 PM
  #385
evolutme's Avatar
This car is so ****ing sick!
Old Jan 8, 2011 | 11:30 PM
  #386
detroit pistins's Avatar
nice progress BJ
Old Jan 9, 2011 | 06:59 AM
  #387
vmrevo9's Avatar
Veteran: Air Force
good luck!
Old Jan 9, 2011 | 08:30 AM
  #388
MJ23FE's Avatar
Damn! Sucks about the surgery, but def let me know when we can chill! Good luck with that ish!
-Jalal
Old Jan 9, 2011 | 09:39 AM
  #389
damn totaly missed the surgery thing, goodluck man!
Old Jan 9, 2011 | 02:48 PM
  #390
06MREvo's Avatar
Originally Posted by detroit pistins
nice progress BJ
Originally Posted by vmrevo9
good luck!
Thanks guys!
