request: someone with hella tones/super tones
Old Sep 3, 2011 | 03:08 PM
jsan1020's Avatar
I want to see how they look but I haven't really came accross anyone who has them. I was going to paint them white for my white 9.
Old Sep 3, 2011 | 04:08 PM
kimma's Avatar
igot them on my ww 03 ...let me see if i can sum up a nice pic
Old Sep 3, 2011 | 08:05 PM
panem's Avatar
Old Sep 3, 2011 | 08:16 PM
bnr34rb26dett's Avatar
check my build thred
Old Sep 3, 2011 | 11:13 PM
OreOs's Avatar
I had white hella horns on my white Evo if you search for my weightless white voltex thread.
Old Sep 3, 2011 | 11:31 PM
wasFWDnowAWD's Avatar
here, i made it easier:
(nice evo oreo)
https://www.evolutionm.net/forums/ev...-widebody.html
Old Sep 4, 2011 | 02:46 AM
nursebetty's Avatar
on my 7
found this on here, hes painted the centre one black
Old Sep 4, 2011 | 03:04 AM
FJF's Avatar
FJF
I run a Hella truck horn (~300Hz). The horn is mounted below the driver's side headlight and hidden by the front clip. I only bought one. Didn't see any reason for a pair, just as I can't think of a reason why the horn should be seen. If only the Supertones were available, I would have painted them black.
Stock next to the Hella. FWIW, the Hella tips the scales at ~1.5lbs.
Old Sep 4, 2011 | 07:18 AM
Brian00's Avatar
Do you have a sound clip of the horns in action?
Old Sep 4, 2011 | 06:01 PM
jsan1020's Avatar
How is the mounting with them? I want to keep both above the intercooler is possible.
Old Sep 4, 2011 | 06:10 PM
Countrystrong11's Avatar
you have to make a bracket for them, I need to get around to doing mine
Old Sep 4, 2011 | 06:42 PM
FJF's Avatar
FJF
I don't. Mine sounds like a relatively big truck. It's easily noticed by other motorists when used as a safety feature, as intended. That was the whole point of the upgrade.
Old Sep 4, 2011 | 08:17 PM
nursebetty's Avatar
i mounted mine to where the intercooler bolts to the radiator support! might be hard having them both there because the fan gets in the way. My orginal plan was to have them both up there to but just mounted the second where the factory horn is!
its longer taking the bumper off then actually fitting them.
Old Sep 5, 2011 | 02:53 AM
OreOs's Avatar
Thanks! but yeah, like nursebetty said, I also made a bracket, just a 7 or so inch long black bracket, bolted it where the intercooler bolts up, and drilled 2 holes for the horns to bolt up to. they are easy to wire, just ground one of the leads and connect the other to the stock horn's positive wire and you are good.
evozoom
17
Aug 20, 2017 05:19 PM
CaptainCrunch
Feb 26, 2016 07:33 PM
tazz33
May 6, 2014 06:52 PM
xbenbendx
Mar 14, 2013 10:39 AM
r.m.s.
Mar 10, 2006 10:53 AM
