Moore Automotives Evo Builds
Old Jan 19, 2012 | 12:32 PM
  #46
Moore Auto's Avatar
A few more pictures Moore Automotives Evo Builds-img00485-20120113-1526-1-.jpg
Old Jan 19, 2012 | 12:38 PM
  #47
Moore Auto's Avatar
Dyno picture
Old Jan 19, 2012 | 01:01 PM
  #48
Josh@MooreAutomotive's Avatar
I will update this thread with better pictures and Dyno results on saturday. The tuneing has been amazeing saying that this was a large turbo and Im on low boost its still making a insane amount of power as of right now.
Old Jan 22, 2012 | 09:15 AM
  #49
Ok one thing we forgot to swap the MAP Sensor during the 3rd run when we started to turn up the boost so the 35.25 is really 38-39 psi and the dyno reads 1 psi higer then what you run so the 42 is 41psi. the 608 run is 3rd gear the 616 is 4th and the 553 is 3rd on 32psi. We had one change and that was to a Buschur SD Catback which picked up 11 whp and 10 ft/lbs with minor af changes but at 32 psi.
Heres the S362 vs FP Black both JB Turbos.
Old Jan 22, 2012 | 09:27 AM
  #50
wjamyers's Avatar
Originally Posted by alex:)ix
bad :/ the turbo is blown or idk it doesnt make more power so im looking to upgrade the turbo i went to another local shop for cams fuel pump n tune long story... im disappointed now lol
u shud post up the story so others can benefit from your experience.
Old Jan 22, 2012 | 09:30 AM
  #51
Or you can PM Him and ask,stay out of this thread with off topic stuff. Read the whole thread befroe posting. it was a Local shop hes from MD not VA. Alex is a good customer of ours and has been and will continue to be.
Old Jan 22, 2012 | 11:57 AM
  #52
My Build 2012
Old Jan 22, 2012 | 04:45 PM
  #53
mxguy1286's Avatar
That bep .70 hot side really restricts that turbo. Get the .88 and you will really see it stretch its legs. Here is one of my dynos with that turbo https://www.evolutionm.net/forums/ev...h-results.html
I have ran it on my talon, and a friend has one on his eclipse. Pretty much anything 600whp and above it stops flowing above 7k.
Old Jan 22, 2012 | 04:51 PM
  #54
Well first thing I need to do is port the head and larger cams.
Old Jan 22, 2012 | 05:05 PM
  #55
mxguy1286's Avatar
What cams are in the car? I have had some great luck with kelford 280cams. Its a lot more work and money to port the head then to swap out the exhaust housing. I am sure you would see more gains from cams and a exhaust housing. My stock head made 720whp d.j. and holds power to 9k without dropping one bit.
Old Jan 22, 2012 | 05:22 PM
  #56
GSC S2 274/274 but this is a T3 the larger housings list T4.
Old Jan 22, 2012 | 05:25 PM
  #57
mxguy1286's Avatar
My bad, .85 t3 housing. Its a 6bolt outlet is the only problem so you will need to remake the o2 housing. http://www.bullseyepower.com/S300.asp And yeah some bigger cams sure would help the power!
Old Jan 22, 2012 | 05:51 PM
  #58
Yeah I want to stay vband next upgrade will be a ball bearing turbo.
Old Feb 4, 2012 | 01:04 PM
  #59
BravoZero's Avatar
Looks like the build is coming together nicely Josh! I think the last time we met, you still had the Eclipse, lol.
I need to stop by Moore and get some quotes on work for the Ralliart, maybe I'll get a chance to see the beast if you drive it there.
Old May 21, 2012 | 10:26 PM
  #60
USCGSAM's Avatar
From: Detroit metro area Michigan/Washington DC metro area
subscribed. SWEET build. can't wait to get my POS back on the dyno. i followed your recommendations and went with S2/beehives and shifted over to SD on the ECMlink and now i need tuning. that said with the way she rides now street tuning isn't an option as it was before(she is a little to quick) from a safety standpoint she is mapped for DD w/o boost. Love the S2 lope/idle :-) i'll be stopping by soon.
