Evo 7 DIY tails done right
So after seeing multiple evos with their diy evo 7 tails, I have been disgusted. Most of the spray jobs look like crap and they fade and whatnot. I knew what had to be done to make the most authentic looking 7 tails.
My buddy picked up a set of authentic 7 tails for himself, so I snagged up his stock 8 tails and painted them.
These were sprayed with SEM candy Koncentrate mid coat. Its a candy apple read, and its transparent. So I masked off the lines at the bottom of the turn signal with 3/16" tape. Scuffed the whole taillight with a red scotchbrite pad and started spraying. 5 coats of the candy apple red(transparent) and 6 coats of clear. This gives me plenty of clear, in case I want to sand and buff the tails so you cant see or feel the tape lines on the signal part.
I am very pleased with the results.
Its SEM color horizons candy koncentrate. Candy apple red. You have to mix that 8:1 with a clear binder. Then mix that misture 2:1 with reducer.
Then spray the clear.
EvoTeyn: You talking about the back of them?
If you are talking about the chrome part thats in the 8s, then no, the 7 tails are not made this way. The authentic 7 tails have the inside of the lens tinted red. The backhousing is still chrome, with a red lens over the top. Thats from everything I have seen and read.
I figured I would just spray the outside of these. Thats the reason for spraying so many coats of clear. So i can sand and flatten the lines and make them smooth as if it were painted from the inside.
the housing of the taillight itself is red, and while the lens may be tinted, a vast majority of the red comes from the housing
Thanks man!
Ill send you a pm.
