Spoiler Carbon Fiber Fading
Subscribe
Oct 19, 2012 | 05:50 AM
I have had this car less than a week. How do I resurface or stop this fading from getting worse?
Thanks!
Reply 0
Oct 19, 2012 | 06:01 AM
search button should be the start.
sand it and reclear. theres a how to on how to do it if you just SEARCH
Reply 0
Oct 19, 2012 | 06:26 AM
Sorry I didn't realize this was a forum for car people helping car people.
Reply 0
Oct 19, 2012 | 07:07 AM
Here's the link to the How-to.
https://www.evolutionm.net/forums/ev...bon-wings.html
I've actually done this myself and it's really not that hard, just takes some time and elbow grease. You can start out wet sanding like the how-to says, but personally, I was getting almost nowhere with the wet sanding. I ended up dry sanding with an 80 grit sand paper to get the clearcoat off. Carbon fiber is pretty durable stuff and you'll be able to tell a difference once you finally get all the way through the clearcoat. You'll start to see dark grey dust from the resin that holds the CF together.
Reply 0
Oct 19, 2012 | 02:16 PM
Same thing is happening to mine and it's spent 98% of its life in the garage but it's a very common problem
Reply 0
Oct 19, 2012 | 09:07 PM
Take it easy he's a brand new member
Reply 0
Oct 20, 2012 | 05:10 PM
I went 600 dry then 1500 wet and then buffed it and sprayed it. Turned out ok. Still not perfect but I am more concerned about protecting it. Probably will have to maintain it every year.
Reply 0
This car was garage kept too! Weird.
Quote: Same thing is happening to mine and it's spent 98% of its life in the garage but it's a very common problem
Reply 0
Oct 20, 2012 | 08:27 PM
Quote: I went 600 dry then 1500 wet and then buffed it and sprayed it. Turned out ok. Still not perfect but I am more concerned about protecting it. Probably will have to maintain it every year.
It depends on how many coats of clear you do. I did mine about a year ago so it already went through one winter and still looks just as good as the day I did it. I sanded and buffed like crazy though and did like 8 coats of clear.
Reply 0
Oct 21, 2012 | 05:13 AM
Here is a before/after of mine to give you an idea of what can be done.
Before
After
Reply 0
Oct 22, 2012 | 04:05 AM
Nice work. I will post a pic of mine. It looks a lot better.
Reply 0
Dec 11, 2012 | 08:36 AM
I did this to my spoiler but it seems like the clearcoat is fading/peeling again. Going to have to give it a round 2 now...
Reply 0
Dec 11, 2012 | 03:13 PM
Quote: I did this to my spoiler but it seems like the clearcoat is fading/peeling again. Going to have to give it a round 2 now...
What type of clearcoat did you use and how long has it been since you did it last? A high quality clear should last almost a lifetime. ....it won't be cheap though.
Reply 0
Dec 13, 2012 | 01:14 PM
I used a canned version from a local body supply shop.
Reply 0
Dec 13, 2012 | 02:55 PM
Question... When the clear is off, and you are down to the carbon fiber... Will u still see the lighter spots in the carbon fiber from the fading? Will they go away as you sand the carbon fiber lightly as u progress?
Gonna do mine soon I think. Got it masked up and ready but a little chicken to start sanding I guess . Was considering just having a body shop sand and paint flat black, but would rather restore if possible.
Reply 0
Subscribe
