How to deactivate ABS
Old Jan 1, 2005 | 04:16 PM
JerryT's Avatar
Hi everybody!
I want to deactivate ABS in Evo 8. The problem is that there are EBD and in my Evo (European one) there is SAYC - all methods I know are not good because the back brakes are not working well after this.
Old Jan 1, 2005 | 04:19 PM
vittorio's Avatar
Just pull out one of the fuses.Bardzo proste.Pozdrawiam
Originally Posted by JerryT
Hi everybody!
Old Jan 1, 2005 | 04:22 PM
JerryT's Avatar
Not working well. EBD is giving too much power to rear brakes when you switch the fuses off.
Niestety - jak napisałem ta metoda nie działa ;P
Old Jan 1, 2005 | 04:50 PM
ray3328's Avatar
You would probably have to splice the wires from the abs going to the fuse box with an on off switch. I think I read that before on sport compact mag with a subaru.
Old Jan 1, 2005 | 04:56 PM
JerryT's Avatar
Fuse method is not working. As I noticed before - this swiches ABS but EBD goes bananas too
Old Jan 1, 2005 | 05:18 PM
xtnct's Avatar
The way I used to do it on my older VW is to disconnect one of the wheel ABS pickup sensors. They have connectors so that they can be replaced. The car should think there is a problem with a sensor and go into fully working non-ABS mode. The ABS light in the instrument cluster would obviously be on to tell you that you have an ABS problem.
Sprobuj to i daj znac. Po co to robisz - ABS w EVO dziala bardzo dobrze.
Old Jan 1, 2005 | 05:25 PM
JerryT's Avatar
A need ALL sensors working for S-AYC so this method is not good too.
Chcę wylaczyc ABS bo na beznadziejnych polskich drogach zwyczajnie czesto wariuje.
Old Jan 1, 2005 | 05:44 PM
dryad001's Avatar
Hmm the fuse thing worked for me, theres a lot of ice on the ground and I just kept sliding.
Sorry not a polack
Ich werde Sie alle töten (just kidding)
Old Jan 1, 2005 | 06:09 PM
xtnct's Avatar
Ahh... warum, warum? Der war nicht ein guter Witz.
Tak, tak, Polskie drogi sa kiepskie ale nadal mysle ze ABS bedzie lepsze niz twoja noga.
Old Jan 2, 2005 | 05:40 AM
vittorio's Avatar
Hilarious.Ja,ja keine luft
As for ABS my car is dancing all over especially on this freezing rain.Thinking about pulling damn fuse as well.Dunno...
wrx_ua
Mitsubishi TC-SST Discussion
Feb 20, 2016 08:09 PM
hatesposers
Oct 10, 2012 06:42 AM
jameswwt
12
Jul 28, 2011 05:34 PM
juyanith
Sep 29, 2009 06:27 AM
rolly1818
10
Dec 23, 2008 10:04 AM
