Rear Trailing Arm Question - Need HELP.
Old Aug 18, 2006 | 07:31 PM
boostedwrx's Avatar
Im going to perform this install as soon as my parts arrive from GTWorks. Anyone want to give me one last piece of advice? I've read most of the threads on here about it, so I think I can do it!
Old Aug 20, 2006 | 03:17 PM
jid2's Avatar
Originally Posted by jbrown
ahhh, I got the Energy Suspension ones, but haven't installed them yet. I believe the Energy ones are split so they don't need to be pressed in. That would save me from removing the arm, right?
Wrong. The stock bushings are in SOOOO tight. I tried using a large threaded bearing press with an impact gun to remove the stock bushings and didn't even budge them. The only way to get the stock parts out is with a hydralic bearing press, which requires you to remove the trailing arm.
And, Enegry bushings are 1 piece - not 2.
Old Aug 20, 2006 | 03:34 PM
Compjoc's Avatar
I highly recommend you get a ball joint puller like the one Works listed at the beginning of this thread.
I didn't have access to a press, so I used a sawzall to cut the rubber part of the OEM bushing out. Then, I used a hack saw to cut the bushings' metal sleave out. After that was done with, I used a vice to press in the aftermarket bushings. Just be sure to grease the bushing up everywhere before you reinstall the trailing arm.
Old Aug 20, 2006 | 04:26 PM
boostedwrx's Avatar
Cool... I bought one of those pullers that Jamie posted at the beginning of this thread. Its off of Ebay, but the picture looks EXACTLY like his.
I'll probably use the other methods you describe as I dont have a press.
Thanks.
Old Aug 20, 2006 | 04:36 PM
Compjoc's Avatar
Sounds good, Just put the puller on and tighten it down (TIGHT). Then hit the knuckle with a metal hammer a few times. If it doesn't pop loose, tighten the puller down more and hit it some more. It will eventually pop loose.
Old Aug 20, 2006 | 05:01 PM
jbrown's Avatar
Fortunately I have a press AND a ball joint puller. Guess I'll be ok either way.
Old Feb 26, 2008 | 11:07 PM
Johnboy1065's Avatar
I know this is a dumb question. but is the rear trailing arm the same thing as the lower control arm??? Just wanting to know what exactly the rear trailing arm is. I'm thinking of buying some buschings for it but I need to know what it is before I do. I've heard people talk good about the whiteline products for bushing.
Old Feb 26, 2008 | 11:54 PM
marksae's Avatar
Here's a diagram of the evo's rear suspension. The "trailing arm assembly" is the arm where the bushing needs to be changed.
Old Feb 27, 2008 | 11:19 AM
ok cool, thanks. I was thinking it was on the front for some reason. I was looking at service manual pictures of the front suspension trying to figure out what ya'll were talking about lol
Sleepless
37
Jun 21, 2021 05:58 PM
jid2
Jun 1, 2017 10:30 AM
Evo8RA
14
May 23, 2017 02:44 PM
R/TErnie
13
Mar 24, 2011 11:24 PM
rawkus
Jan 9, 2009 07:59 PM
