the end all tire (and wheel) thread
Subscribe
May 10, 2006 | 07:35 AM
  #31
ok the thread is done, this will likely be the last update i perform... i'll talk to mods about cleaning the thread and making a stickie.
like always anyone is welcome to ask me questions about anything. pm me freely.
Reply 0
May 10, 2006 | 07:52 AM
  #32
How about adding tire diameter information? E.g. stock is 25.3", a 255/35 is 25", a 255/40 is 26", a 265/35 is 25.3", etc.
l8r)
Reply 0
May 10, 2006 | 09:32 AM
  #33
i put the tire calculator in for that, the other thing is i don't want to misadvertise anything as each manufacturer of tires uses a dfiferent tolerance standard and they can vary hugely from the advertised "grid" sizing. take hankook for example... they deviate a lot from all other manufacturers in width.
Reply 0
May 10, 2006 | 10:35 AM
  #34
When I did research on the 5Zigen Fno1c-r 18x9.5, most stores recommend 235/40/18 tires!
You say that's too thin? Is it that bad??
Reply 0
May 10, 2006 | 04:56 PM
  #35
i could say a lotta things right now but here's what i'll say.
for one, the stores are recommending a bad size, likely becuase you're running a huge wheel and they don't wanna be bothered with you not being able to fit it. that said as long as you generously roll the rear fenders you will be able to fit up to 275 35.
the stock tire is a 235 45, to kick it down to 40 would make it thinner, is that too thin? for an 18, no. could you go thicker? certainly. do you want that much tire stretch on a 9.5" wheel? only if you want to show off your rim bead.
Reply 0
May 10, 2006 | 06:10 PM
  #36
Quote: FALKEN AZENIS RT-615
comes in
255 40 17,
235 40 18,
245 40 18,
275 35 18.
You probably also want to mention 245/45/17. For SCCA street touring (STU), that's the widest you can legally go on the stock (or any other 17") rim.
d
Reply 0
May 10, 2006 | 06:23 PM
  #37
Quote: You probably also want to mention 245/45/17. For SCCA street touring (STU), that's the widest you can legallu go on the stock (or any other 17") rim.
d
i don't recommend that size. 245 40 is better
Reply 0
May 10, 2006 | 08:25 PM
  #38
Quote: i don't recommend that size. 245 40 is better
Except the 615 isn't made in 245/40/17.
d
Reply 0
May 10, 2006 | 08:32 PM
  #39
a problem i thankfully do not have to deal with hahahaha
Reply 0
May 10, 2006 | 08:36 PM
  #40
Quote: a problem i thankfully do not have to deal with hahahaha
Sure, but you wanted this to be the end all -- be all, right? It looks like the folks who want to be competitive on STU are running 245/245/17, so I was suggesting that you at least list it as a possibility. We'd all be running 255/40 if the M3 guys didn't complain about those pesky "rules".
d
Reply 0
May 11, 2006 | 06:30 AM
  #41
Quote: i could say a lotta things right now but here's what i'll say.
Ok, with that said. I really don't want to get into the whole rolling the fenders thing. Therefore, other options besides 255/35/18 (which is what I've mostly seen), for a 18x9.5" rim, would 245/40/18 be an issue with rubbing and a 35+ offset??
Reply 0
May 11, 2006 | 11:30 AM
  #42
255 actually shouldn't rub, especially since you're already stretching that with a 9.5. 245 will just be that much thinner.
Reply 0
May 11, 2006 | 12:22 PM
  #43
Quote: 255 actually shouldn't rub, especially since you're already stretching that with a 9.5. 245 will just be that much thinner.
Ok, not doubting that the 255 would not rub with 35 series tire...however what about 40 series since the wall is bigger?
Reason for that is I'm worried about the ride quality with a 35 series tire being so damn thin and riding right on the rim. At least maybe a 40 series would give it some more room. Therefore thinning out the width a bit using 245's with a 40 series wall to make up some??
Reply 0
May 11, 2006 | 12:47 PM
  #44
uhm... i just said that the 255 35 would not rub... are you asking if 255 40 will rub?
Quote: tires i don't recommend running, 245 45 17 and 255 40 18. these are tall will rub and don't give you enough grip to justify the rubbing.
with that said... on a 9.5 rim the 255 40 will be stretched more and will give more clearence. however i still do not recommend it.
you should try using hte tire diameter calcualtor that i provided in the first post. it's very good and easy to use for comparisons. otherwise, don't deviate from the sizes that are known to work.
Reply 0
May 11, 2006 | 12:57 PM
  #45
Quote: uhm... i just said that the 255 35 would not rub... are you asking if 255 40 will rub?
lol! I figured this would get confusing. I'm asking if 245/40/18 would rub on a 9.5" rim with 35+ offset???
...I already know 255/35/18 would not.
Quote: you should try using hte tire diameter calcualtor that i provided in the first post. it's very good and easy to use for comparisons. otherwise, don't deviate from the sizes that are known to work.
Yeah, I'll try that.
Reply 0
