Racing Brake Wheel Studs
Old Oct 31, 2006 | 03:51 PM
Tsurara's Avatar
Quick question for RB wheel studs owners, maybe you guys can save me a call to RB
Are the RB extended wheel studs ones you press in, like the Kyo-Ei studs?
Any information would be appreciated. Also, if anyone knows any extended studs that can be hammered out, I would appreciate it.
Old Nov 1, 2006 | 04:46 AM
kekek's Avatar
I believe any wheel stud for this car will be press in. Without the press fit, surface area contact will drop between the stud and hub increasing the likelyhood of stripping the hub/stub then you're SOL. FYI, hub/wheel bearing assy's are around $150-$200 from Mitsu.
Old Nov 1, 2006 | 06:33 AM
ballistic speed's Avatar
i was able to buy the open ended lexus lug nuts and i put a 16mm? deep reach socket over the unpressed stud that had been inserted into the stude hole, and i took an impact wrench and scrwed the open ended lug over the socket and that pressed all of them in, i did this with my arp extended. So basically, insert the stud into the hole and make sure the stude is snug with the hole and the kurled area, then place a 16mm deep reach socket over the stud and thread on a lexus oepne ended m12x1.5 lug nut over the socket and impact it on. BTW, it doesn't take that much force i was using my electric impact gun which only puts out 100ft/lb max
Old Nov 1, 2006 | 10:14 PM
evo-mike's Avatar
good to know, i got my arp's on the way. thanks.
Old Nov 2, 2006 | 12:06 AM
RazorLab's Avatar
That's a good way to stretch the studs and make them weaker.
Old Aug 23, 2007 | 03:21 AM
EVO8LTW's Avatar
What is the correct way to install longer studs?
Old Aug 23, 2007 | 04:52 AM
SwabeLife's Avatar
+1.... is there a how to for this?
Old Aug 23, 2007 | 07:41 PM
kekek's Avatar
With the hub assy removed from the car and studs pressed in/out without loading the hub bearings. Royal PITA unless the whole car is apart.
Old Sep 29, 2007 | 04:27 PM
MajorPayne's Avatar
not true
this is how we install studs on race cars when pressing them in isnt an option and we never have any problems
bnr34rb26dett
Dec 13, 2015 01:45 PM
cody92talon
Dec 27, 2011 06:41 AM
wasFWDnowAWD
Sep 19, 2011 09:51 AM
Markourn
64
Sep 13, 2006 12:24 PM
Tsurara
Feb 28, 2006 05:30 AM
