Brake DIY
Old Mar 9, 2007 | 12:26 PM
Profoxcg's Avatar
Brake DIY
Is there on with pics? I have done brakes on my civic before but never on a 4 piston caliper. do i need a especial pad spreader? help please.
Old Mar 9, 2007 | 12:30 PM
4WS Tuning's Avatar
just do 1 pad at a time... i used 2 flat head screw drivers to press both pistons in
cheers!
Old Mar 9, 2007 | 01:05 PM
Profoxcg's Avatar
so there is not pad spreader tool?
Old Mar 9, 2007 | 02:00 PM
rsboy's Avatar
yeah the flat head screwdriver!
seriously.. changing brake pads on the evo is just too easy! check the DIY forum.
Old Mar 9, 2007 | 04:20 PM
Profoxcg's Avatar
i looked and all the thread have no pics.. urgh
Old Mar 9, 2007 | 04:23 PM
RedAustinIX's Avatar
I haven't actually changed my pads yet, but this how-to video looks pretty helpful.
http://videos.hspn.com/?videoid=46
RedAustinIX
tripperfx3's Avatar
It really is truly easy and i think evomoto.com or machevo.com made a 4 piston spreader, but its fairly expesive. If you do it alot its work it, but i believe its around 110 to 120 bucks.
Old Mar 9, 2007 | 04:25 PM
MYEVOVIII's Avatar
All you have to do is swing one of the two pads around and use it to spread the pistons back. Our cars have about the simplest to changes brakes out there. All you need is a 1/8 in punch and a hammer and your done....
Old Mar 9, 2007 | 08:06 PM
4G63's Avatar
What he said...just be careful not to chip your paint on the calipers!!
Old Mar 9, 2007 | 08:11 PM
EVO8904's Avatar
The paint chips on its own......
Old Mar 10, 2007 | 05:59 AM
mdosu's Avatar
http://videos.hspn.com/?do=showcat&catid=14
for pads, note: the guy on the video didn't use anti-sieze nor did he put his shims back on.
Old Mar 10, 2007 | 08:12 AM
evoCS's Avatar
This tutorial has pics, you've just got to click on them to see. It's the best one I've seen on here:
https://www.evolutionm.net/forums/sh...ad.php?t=77123
Hope this is helpful. Also, you can use the pad you're removing as a tool to push back the pistons as well.
Old Mar 10, 2007 | 08:29 AM
reggiesd's Avatar
that was a pretty good write up.
Old Mar 10, 2007 | 09:29 AM
gamma500's Avatar
Have found that hooking up bleeder bottle and cracking bleeder screw makes for an easier pad pushback...less force needed and pushing one side back doesn't pressurize the opposite side pistons causing them to push out. Also accomplishes a mini brake bleed.
Nov 21, 2011 09:43 AM
Mivo
Northwest Region
11
May 13, 2011 09:28 AM
Boba
Mitsubishi TC-SST Discussion
Jan 6, 2010 10:59 AM
SuckaFree
12
Sep 1, 2006 03:04 PM
davids2004
11
Apr 20, 2006 01:34 PM
