beatrush rear diff bushings deff worth getting...
you do NOT have to drop the diff...you take one bolt out and back the other one out just far enough to remove the one side. pull out the stock rubber bushings put in your new ones and put the bolt in just a few threads take out the other side repeat. tighten them both up.
if you have a cordless impact gun it takes about 10 minutes to do.
just note the beatrush bushings have a thin one for the top and thick for the bottom.
did the same thing with the drive shaft bushings but the stock onces are a little harder to pull out. they are stuck. you need to grab them with some needle nose and rip them out. use a screw driver to.
we put these in and the exedy hd twin disc this past friday. the car feels great.
cal1mr
15
Aug 13, 2008 01:09 AM
cal1mr
Feb 15, 2008 09:54 PM
