Alignment, what do you guys run?
Well now that im at
uti i can do my own alignments.
what do you guys run for specs? Stock on everything? or what do you usually use for specs?
im lowered a little on megan coilovers so i have camber plates.
My set up will be slighty aggresive and will vary onwhat tires and winter.
Street- 1.5-neg. camber front 0 toe
rear .8-1.0-neg. camber 0 toe
Track, front 3.0-4.0-neg. camber 0 toe
rear max allowed for me 2.0 neg camber
Drag ive never set up for but i would believe 0 all the way around might yield the most traction hope this helps a little.
street and aggressive driving FRONT (-1.5 degrees camber) (-0.3 toe out) REAR (-0.9 degrees camber) (0.8 toe in) add or take a couple for more aggressive driving
for drag, positive camber in the rear because of how the rear suspension reacts, helps it hook up.
rodeopunk_je87
Aug 5, 2014 03:45 PM
damie45
Jul 25, 2009 02:09 PM
PaRanHaNeul
16
Nov 7, 2008 05:08 PM
andifidie
24
Jun 26, 2007 11:40 AM
