View Poll Results: What coil over is better for street and once a month track use?
Tein Flex
66
24.54%
Tein SS
15
5.58%
HK hypermax II
38
14.13%
Cusco Zero 2R
62
23.05%
JIC FLT A-2
88
32.71%
Voters: 269. You may not vote on this poll
coil over poll. Working Poll this time
Originally posted by SOF
We're talking about coilovers here, not piggybacks.
This conversation is over.
Im not going to waste the time to explain this to you, but its called an analogy. Its a form of reasoning.
What's the point of getting coilovers if you don't custom tune them? If you're getting coilovers, then obviously there is some aspect of the stock suspension that you find lacking, and are therefore replacing/upgrading.
The advantage to using coilovers is customizability with multiple dampening and rebound settings that allow you to adjust the car to your driving style. If you just buy coilovers, install them, and pray to god that somehow your car will handle infinitely better... well, then more power to you.
EDIT: Might I add that, this isn't a Civic with crappy suspension - Mitsubishi specifically stated that the suspension on the car was so finely balanced that unless you really knew what you were doing, you'd probably do more harm than good.
Piggybacks need to be tuned. Properly built coilovers don't. Comprende? Swapping out springs on a near $2k set of coilovers is ridiculous.
if I were to tune my car for daily driving in southern california with the occassion spirited racing - track or otherwise (on tarmac) what do you recommend as far as a coilover set for a beginner driver (just started driving stick 11k miles ago)? I am looking for an affordable setup (under $3k) that can be properly tuned - so from reading this thread it seems JIC FLTA2 setup is well suited for my needs. Also wondering - when you do a custom setting for suspension are you re-valving or setting the damper rate?
Basically I want a sport-tuned suspension for daily driving just not all extremely raced out, practical with a sense of race settings so I can still race.
Anyone heard about KG/MM coilovers? Also can Cusco Coilovers be tuned?
Are you asking about coilovers for your RX-8 or for an Evo 8?
Anyhow, KG/MM coilovers are great on Hondas. Good ride on street with great settings for the track. However, I have not heard of these coilovers being offered on an Evo or RX-8... are they?
Cusco Coilovers can be tuned depending on which setup you get and their individual adjustability. What you can do is get a setup that has dampers with a really wide range of adjustments from really stiff settings to fairly soft ones. Once you get that done you can get custom springs that are only a little stiffer than the stock springs. This way you can set you your car to soft settings while tooling around town and firm it up when you attack the canyons.
Let us know what you decide.
I have had JIC's and Tein's. Don't waste your money on them, Spend the extra couple of hundred dollars and get HKS, Cusco, Ohlins. I have the HKS on right now and they are 1000 times better than the JIC's. If you look around I am sure you can get them somewhere for less than $2000.
