Removing the brake disk shields Good - Bad - Why
Old Dec 7, 2009 | 12:06 AM
fireroasted's Avatar
On my other previous track/dialy car, a WRX, I removed all the brake disc shields. My reasoning was that they would cool better. I serviced and checked the brakes often and never had an issue.
My Evo brakes like a brick wall with DTC60s. At my last track day at CA Speedway though I got some fender liner bits stuck between the shield and inside against the disk. I don't have brake fade, actually ever, but I was thinking to remove the shields to allow for better cooling.
Let me know what your guys, especially the track gurus think and why. Thanks
M
Old Dec 7, 2009 | 04:44 AM
black95tt's Avatar
Make sure to put a heat shield of some sort over your ball joints or expect to have melted dust covers.
Old Dec 7, 2009 | 07:23 AM
TommiM's Avatar
+1. The shield is there to also keep heat away from the wheel sensors along with not melting the rubber dustcovers on your ball joints. Maybe coating the shield with some thermal dispersant coating?? Curious if that would even be worth it.
Old Dec 7, 2009 | 07:51 AM
4cdndctn's Avatar
I removed the heatshield and added to ducting. The dust cover argument carries merit but I have not had that issue in the 5yrs of tracking this Evo with similar brake power as you (DTC-60's or RB ET900s).
Old Dec 7, 2009 | 08:41 AM
Smike's Avatar
Shields are needed. Protects suspension and alignment parts from heat and dust. Shields water from inside of rotor (thermal shock issue in rain). Directs some air to the rotor surface, rather than allowing the air to to where it wants to flow.
If you want better cooling - ducts. Proper, attached to the caliper - ducts.
TTBEvoX
13
Jul 29, 2016 01:14 PM
EGbeater
Jul 23, 2016 08:16 AM
chad99evo
Oct 3, 2011 04:56 PM
EVIL_EV0
Nov 27, 2008 10:17 PM
theblue
May 15, 2007 07:58 PM
