how do I remove the brake shields?
I'm looking for a "how to" for removing the brake shields. does it bolt on or do I need to dremmel?
thanks in advance for any links or advice.
Can I ask why you want to remove...there is really no extra brake cooling capacity without them. In fact, I know of at least one avid track driver that came in from a session with his ABS sensor wire on fire and his bottom ball joint boot melted because he removed them.
RobiSpec has done some testing with this same outcome: no benefit to removing them.
Now if you're doing it to install a brake cooling duct kit, that's a different story.
As far as how to remove...dunno. Just wanted you to be informed.
Remove the two 19mm bolts that hold on the caliper, slide the caliper off the rotor, remove the rotor, and then remove the 10mm bolt that sits behind the hub. Be sure to tie down the abs sensor wire or you will cook it.
thanks, got it....
the back story is that I fried my entire brake system at the track... the dust shields are gone now... I'll also be adding brake guides or ducts (still figuring out which I want)
also will be stepping up to some dedicated track pads.
when I came off track the shields were really hot... so I refuse to hear that they're not trapping heat.
thanks, got it....
TTBEvoX
13
Jul 29, 2016 01:14 PM
EGbeater
Jul 23, 2016 08:16 AM
jeffpinto
Mar 21, 2015 03:27 AM
