Torrington Bearings, who's got them?
Old Jan 4, 2010, 07:07 PM
chu
chu's Avatar
I first noticed them on the PIC Performance coilovers, and thought that it was a great idea. I know some more expensive brand coilovers come with them also. They must serve a good purpose because even Hyperco make a hydraulic version. I recently purchased a set of used Ohlins, and thought it will be a nice addition if they didn't already have them. Wanted to hear experiences, good places to get them, and if I really need a set for both upper and lower perches, or a just the lower one. I've already pm'd Andrew from GT Worx. Just wanted to hear some others opinions. Thanks.
Old Jan 5, 2010, 05:41 AM
chu
chu's Avatar
27 views and no ideas?
Old Jan 5, 2010, 10:00 AM
spool_sample's Avatar
I've used Torrington bearings on just about every coilover I've owned. They reduce spring stiction, which will increase mechanical grip slightly (springs twist as they compress) and cut down on creaking noises at low speeds or at a stop. They also make adjusting ride height super easy since you don't have to compress AND turn the spring when you turn the perch.
The Hyperco perches do a lot of the same but are way expensive and supposedly have to be rebuilt often, which is also way expensive. Torringtons should get you most of the way there for about $100. I usually clean/grease mine once or twice a season and replace them annually.
I get mine from Performance Shock (www.performanceshock.com). They have sets for 2.25", 2.5", and 60mm springs. Ohlins have 60mm springs, I believe. Buy 4 sets of them, one for each corner. Running 2 bearings per corner is fine, but it's not necessary. Put them on the lower spring perch (under the spring), and you're good to go.
They won't make or break your suspension setup, but they are definitely nice to have.
Old Jan 5, 2010, 10:17 AM
RaNGVR-4's Avatar
Spring twist takes a linear rate spring and gives it a bit of progressive rate change. But its pretty miniscule. I dont see it making 100 bucks worth of difference, but if money no object, yes they work.
Old Jan 10, 2010, 08:40 PM
Caffeine Slug's Avatar
Summit has them: http://www.summitracing.com/parts/HAL-7888-109/. A little over $50 to put one on each corner.
Old Jan 11, 2010, 12:50 PM
Evotech8's Avatar
Are they sealed bearings??
They look like a pain to keep dirt and moisture out of them?
I guess on the track it doesn't really matter, but for street duty might not be worth it unless they are sealed from the elements.
Old Jan 11, 2010, 01:06 PM
chu
chu's Avatar
They're not sealed, but the price noted in the above post is wrong. Its about $25 per spring purchased at a suspension shop. It may not add much to the performance, but I hear it great for adjusting perches. I think its worth it for my Ohlins!
Old Jan 11, 2010, 01:10 PM
jasonn's Avatar
Some coilovers actually come with these and yes, they're a ***** to keep clean!
03EVO-VIII
28
Oct 12, 2021 06:33 AM
MRevolutionX
25
Mar 21, 2016 11:03 AM
NicolaRalliart
Mar 29, 2012 04:30 PM
aziankingz
Dec 28, 2011 07:20 PM
Kurt
78
Nov 30, 2007 08:55 PM
Quick Reply: Torrington Bearings, who's got them?
