Rotors Loose
Old Mar 29, 2010 | 09:18 PM
4G63 T's Avatar
Rotors Loose
To make it short, after i loosen Front caliper and removed brake pads i noticed
both FRONT Rotors were loose, literally i can slide them out effortless.
Is it normal?
Old Mar 29, 2010 | 09:23 PM
twabtoxer's Avatar
when i did mine i had the same thing , the rear ones were stuck i actually had to spray some bp blaster to get them out. i think youre fine
Old Mar 29, 2010 | 09:27 PM
BluEVOIX's Avatar
Is it normal?
The rotors are sandwiched between when you bolt on the rims.
Old Mar 29, 2010 | 09:54 PM
4G63 T's Avatar
Really? looks scary..
Old Mar 29, 2010 | 10:05 PM
sphinxof2006's Avatar
Also how did u install pads? U don't have to unbolt n e thing on the calipers just the pins on them need to come out. Rotors are basically floating untill u bolt up the rim, as someone previousely stated
Old Mar 29, 2010 | 10:21 PM
TommiM's Avatar
the lugnuts will keep everything centered on. some cars use a small bolt to secure the rotor, thats really only for the assembly line to keep the rotors on the car during assembly though.
Old Mar 29, 2010 | 10:27 PM
4G63 T's Avatar
ok, nothing wrong then ...
Old Mar 30, 2010 | 04:44 AM
Smike's Avatar
This.
Old Mar 30, 2010 | 10:57 AM
Boltz.'s Avatar
FCOTM Winner
If a wheel falls off when you are driving you won't have to worry much about that rotor helping you stop.
Old Mar 30, 2010 | 11:14 AM
javicracer's Avatar
our rotors are what they call floating rotors, they stay in place tnx to the brake pads, and they get secured against the hub with the tire
Old Mar 30, 2010 | 12:58 PM
4G63 T's Avatar
That's Itsasushi engineering i suppose. lol
Old Mar 30, 2010 | 01:08 PM
gsrboi80's Avatar
Most all cars are that way man except a certain few which are incapsulated with the bearing assembly as I call them and have to be pulled off. Late model Honda Accords for example
Tommyy
Oct 21, 2015 09:16 AM
nickolime
Sep 1, 2015 08:19 AM
Jozino
Nov 14, 2011 02:00 PM
03silverevo
Aug 22, 2007 03:43 PM
sykou
Mar 7, 2006 09:48 PM
