odd grinding from passenger side wheel
Old May 29, 2010 | 08:17 AM
evolutioner27's Avatar
Recently I had my ACD Pump replaced and I did breaks on my IX. Since then I have been hearing a quick grinding noise from the passenger front wheel. It almost sounds like when u run over a crushed pop can. The really weird thing is it only does it the first time I break hard after starting it. It's driving me nuts. Everything looks fine with the breaks no uneven wear or anything and it all feels normal while driving. Any thoughts on what to check next?
Old May 29, 2010 | 08:39 AM
delongedoug's Avatar
Did you bed the pads in properly?
Old May 29, 2010 | 08:49 AM
Yeah they were bedded properly.
Old May 29, 2010 | 09:43 AM
iEvoIX's Avatar
Make sure that the caliper is securly bolted back up to the rotor. You might be causing more damage now if you continue to drive.
Old May 29, 2010 | 09:54 AM
wizzo 8's Avatar
Check your backing plate to make sure you didnt bend it on accident
Old May 29, 2010 | 12:31 PM
I checked the caliber bracket bolts as well as the dust guard and it all looks good.
Old May 29, 2010 | 12:54 PM
Minion's Avatar
switch the pads from side to side and see if the sound moves to the other side.
bdonIX
Dec 18, 2012 02:22 AM
Chaz17
Nov 22, 2011 09:00 PM
mitsuevodriver
Feb 22, 2010 01:50 AM
evoinit
15
Oct 30, 2004 07:31 PM
