lowering evo
Old Nov 16, 2003 | 01:12 AM
rizalhoo's Avatar
lowering evo
Hello,
I wanted to lower my evo by changing the spring. I was thinkin of getting the tein spring. anyhow do i need to change the camber kit ? I dont wanna get any trouble with my tires and all just because i dont have the camber kit changed.
anyone has install camber kit to their's car?
anyone havent? any problem with the car or not?
last question, does anyone know the price on those camber kit range from ? which camber kit do u guys recommend? thanks a lot in advance =)
Old Nov 16, 2003 | 09:33 PM
HIGH REV's Avatar
Depending on how much lowering you're planning on doing, you definitely need a camber kit. You need to utilize your tires efficiently for sufficient handling.
Old Nov 16, 2003 | 09:44 PM
solarxclipse's Avatar
I've lowered my Evo with Tein S Tech springs for about 2 months now, tires and handling are doing pretty good. The car doesn't pull to either left or right. Haven't done any alignment.
Old Jan 2, 2004 | 09:17 PM
rizalhoo's Avatar
Ok, Did my lowering using TEIN S-TECH last week.
For those who lowered their evo with TEIN S-TECH, do u need camber kit?
I heard that evo's stock rear camber kit is adjustable...is that true?
Old Jan 3, 2004 | 06:49 AM
Diesel's Avatar
yes, camber is adjustable at all 4 corners...
a good alignment shop should be able to make the adjustments for you...
Old Jan 3, 2004 | 02:04 PM
rizalhoo's Avatar
So does that means I do not have to get another camber cor. kit?
Old Jan 5, 2004 | 03:04 PM
boostedwrx's Avatar
save for some coilovers. your handling will be affected without properly corner weighting the vehicle. The stock EVO suspension is fantastic, and by tampering with the ride height, the struts will be out of whack.
Old Jan 8, 2004 | 06:14 AM
Benjamin's Avatar
I can attest to that. I just lowered the car with tanabe springs and it drove all sloppy like a truck. Until I got an alignment done and they adjusted the toe in the rear.
Evoguy!123
Mar 24, 2017 10:55 AM
mywht03
16
Mar 20, 2008 09:18 AM
AhmadHasib
Jun 12, 2006 11:00 PM
HaHAAHhAHHAH
20
Mar 24, 2006 04:40 AM
Gumpy
13
Nov 28, 2003 09:37 PM
