Tire / Wheel Fitment Questions
#2927
Tire choice...
I just ordered a set of Rota Grids in 18x9.5 +20. Now I am wondering about tire fitment choices. I figure a little fender work in the rear is required. What about tire sizes?? 245 or 255 seems to be the consensus but any feedback would be helpful. Thank you!
#2928
Your biggest battle is getting the +20 to fit correctly w/out rub & w/out adding out of spec camber. This set-up will need the full rear fender treatment (roll, pull, bumper bolt & other tricks)
#2929
Just as an update, I got my Enkei 18 x 9.5 +38s put on with 245/35 tires!
+20 mm spacers with extended bolts up front, none in the back.
Car is lowered on Tein springs
Minor rub on full lock turning but that's it.
I will need wider front fenders or the fender mod like MinusPrevious said I would haha
#2930
#2934
Quick comment on the question of running different width rims. Dont do it
One of the best fit-ups IMO is the 17x9.5 +38 w/a 20mm spacer up front
This thread has that example
https://www.evolutionm.net/forums/ev...nfirm-plz.html
#2935
I really like RPF1's except for the spacer requirement. Dont think many run the +45's
#2936
There are some good choices of wheels that dont need spacers (i.e. Volk, Advan, Rota, Wedsports, 5Zigs)
You will have to search around & see what you like & fits your price point.
At one time I was anti wheel spacers but today I would run the RPF1's
#2937
16" rpf1 fitment?
Anyone know if 16" rpf1s +35 or +43 will clear the calipers with or without spacers? Looking for a good 16" wheel for the track. Any suggestions??
#2938
The searching I did shows all high offset XXR's will need a spacer. The wheel noted by you is very, very conservative in width & offset. Personally would rather see a more aggressive choice
Heres a search string which may give you some ideas:
https://www.evolutionm.net/forums/se...rchid=21632930
