Help! What's needed for these wheels to fit?!
Old Mar 14, 2011 | 08:41 AM
DSM1320Josh's Avatar
Ok I'm new to my Evo! I have these wheels left over from my DSM. They are Rota P45F 17 x 7.5 +45 offset. If someone could help me by letting me know whats needed for them to fit! that'd be great! If I'm posting in the wrong area I appologize not looking for rude feedback just some friendly help! Thank you in advance!!!
Old Mar 14, 2011 | 09:00 AM
goodhart's Avatar
They should fit as long as they have enough backspacing. Not sure why You'd want to put narrower wheels on than your car has stock though? I would sell them and get a set that is better sized for your car if I was you. Good luck
Old Mar 14, 2011 | 09:05 AM
L888Apex's Avatar
+1 to what he said^^^
Why would you put a skinnier wheel on? Makes zero sense.
Old Mar 14, 2011 | 09:06 AM
They don't. What are stock wheels 8? 8.5?
Old Mar 14, 2011 | 09:24 AM
L888Apex's Avatar
Stock wheels are 8" wide.
Old Mar 14, 2011 | 09:33 AM
Ok thanks! Whats the hub bore size on the Evo?
Old Mar 14, 2011 | 10:16 AM
goodhart's Avatar
67.1 I believe
Old Mar 14, 2011 | 11:30 AM
BenJ's Avatar
Correct, stock evo center bore is 67.1. +45 offset wheels on the evo are no good. Going to run into clearance issues with the calipers and or the suspension. As noted above, a narrower wheel is also a poor choice for performance, unless you are going for top speed runs where minimal resistance is needed.
danielsl1999gsx
Jul 23, 2016 10:45 AM
SupraJunky101
For Sale - Wheels / Tires
Jan 23, 2016 12:14 PM
dsm25psi
Aug 10, 2007 12:20 PM
bishiboy
Jun 21, 2005 09:08 AM
hawaiidiverx
Aug 13, 2003 12:45 AM
